Question about GE APH10AA Air Conditioner
My ge window unit is blowing lots of water out the front of the unit it is a new unit what can i do about this problem
  • 29 Answers
You might try running the fan on a lower speed so that it does not blow so hard. Also, you appear to be in a high humidity area. Continue to run the unit to cool the room and as the humidity drops, The amount of water the unit is making will be reduced thus curing your problem.
Posted on Jul 06, 2010
Air conditioning unit blowing warmer air even when unit is set on 70 and then will blow for 10-15 minutes and then cut off for 5-10 minutes before coming back on again blowing warm air.
If its a window unit, pull out of window get to the front fins might have to remove a few screws on the sides of front and spray out with a hose be careful not to get control box wet.spray fins and wheel inside, dump water out the back or side, put back in window it should start blowing cold air if not then its time for a new one.but sounds like its getting over heated
Aug 28, 2017 | Heating & Cooling
Does the GE a/c asr05lcs1 take water
No you do not add water to A/C unit,its job is to remove moisture from the air,so make sure it is draining out the back ,if it wont blow cold after that get rid of it ac units are not to expensev anymore good luck
Jul 21, 2012 | GE ASR05LC Air Conditioner
I have a GE clothes washer,I bought in 2005.I am having some problems with it.Yesterday,it ran thru all the cycles on the control.I had to shut it off.Today,the water level,did not shut off,so the water...
I have had a lot of problems with the GE top loaders where the pressure switch hose on the tub gets caked up with debris. first i would take off the front panel, all you need is a putty knife where the top meets the front panel, about 2-3 inches from both sides are small clips you have to lift up slightly. after that the pressure switch hose should be on the tub left hand side. pull it off and clean both the tub connection and the hose with a pipe cleaner.
but your original problem with the unit constantly running through all the cycles i would have to know what model # it is to say for sure but it could be the mechanical timer, or if its digital it may need the control unit.
but clean the pressure switch hose first.
Feb 10, 2011 | GE Washing Machines
I have a GE WCVH 6260 front loading washing machine. It has a massive tear (approx. the bottom third) in the rubber door seal. All the water drained inside the unit, beneath the tub, on down to the floor...
Please join us in this petition to have GE recall this front loading washer! Thanks :)
http://www.thepetitionsite.com/739/633/604/recall-ge-wcvh-front-loading-washing-machines-due-to-smoking-fire-hazard/
Dec 01, 2010 | GE WCVH6260F Front Load Washer
We have a window unit model ash08fas1 and it is leaking water into the window to our carpet. Does this model come with a drip pan or plug that needs to be moved? And how do we access it?
Look at your unit from outside the house. The back of the air conditioner should be slightly lower than the front. If it is level or the front of the air conditioner is lower it will drip into the house. Some window units have a drain for the water outside and some don't. Look for a hole in the bottom of the unit outside and if you find one make sure it is not plugged. Also dirty coils can cause a frost buildup on the inside of the unit. This will drip also. If this is the case you should see the ice buildup by removing the front cover or removing the front filter.
Jul 04, 2010 | GE ASL05LA Air Conditioner
Blowing water out the vents.
There is a water pipe from AC to outside,
if a lot of gel inside the pipe, it can make water flow become jam.
Clean it by blow the pipe with a compressor from outside.
Sometimes I did it with my mouth. LOL......
But its worked finally.
Sep 06, 2009 | Goldstar LG LW1804ER Window Air...
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Aug 24, 2008 | GE APN10AA Portable Air Conditioner
Water leaking from portable air conditioner
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Jan 23, 2008 | Heating & Cooling
Thru wall GE A/C
Hi, If this is a new unit I would check the filter first and make sure it is clean. Also check and make sure it is slightly tilted to the outside. If its an older unit it probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem.
Aug 27, 2007 | Heating & Cooling
GE APH10AA Air Conditioner Logo
303 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
