Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
LCD Screen - All the black is green
I have a 37" ambilight and all the black is green- it was intermittent and i thought it was the cable feed b/c when i restarted the whole system it went away but now it is permanent and acts up on dvd. any suggestions??
  • andy b 76 Apr 18, 2008
    i updated the firmware and still having the problem- thanks for the comment- any more suggestions??
    Sergeant:
  • 395 Answers
Go to the philips web sight and download the latest firmware upgrade unzip and store to USB flash stick and follow the instructions on installaition.
Posted on Apr 17, 2008
  • Robert Johnson Apr 18, 2008
    if the firmware doesn't work then check the LVDS cable inside the set reseat it from the SSB board and the panel it is the round tan cable. if that doesn't work then the SSB board needs replacing. have a tech replace the SSB because of the differant screen diversity codes and the option codes that need to be set when replacing the SSB modual. if your set is the 37pf7320a then the part # is 3104 328 42641.
Sanyo 37 LCD ce37ld33-b
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Sanyo Televison & Video
My philips 47 ambilight the screen will just go black turn tv of and on again ok for ten then goes of again
These problems can also be caused by loose contacts in power outlet, RC jacks, cable and sockets.
Aug 19, 2012 | Philips 52PFL7422D/37 TV
Getting green interference on lcd tv especially on
unplug your lvds cable going into the control pcb reconnect cable into the control pcb.if this does not work replace control pcb first,then also could be a defective panel.
Jul 15, 2009 | Televison & Video
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Green Line in Philips 42TA648BX/37 42" LCD
Just a guess. Try to get hold of a different cable box & see if you have the same problem. If so, problem is with cable box.
Jan 15, 2009 | Televison & Video
My 37'' Vizio LCD TV has a green haze and lines on the TV
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
Nov 15, 2008 | Vizio L6 20.1 in. HD-Ready LCD Television
Green noise in black areas of picture
I'm sure you all thought of this but if someone does not state the easy fix then the easy fix doesn't get done.
I had the same thing happen to my Sam46inch1081, it just started doing it, no slow fade in over time.
I have cable with the HD box, all I did to fix it was unplug the power from the back of the hdbox, wait a few seconds plug power back in and have it reboot. Problem was solved.
Like I said, easy fix for me, don't know if this will help you, but ya never know.
Just thinking out loud here but maybe its not your tv but some other equipment you have added to it other than the hdbox.
Dec 18, 2007 | Televison & Video
Audio pops intermittently
Had the same problem, but it went away when we changed satellite receivers. Works perfectly now. I think it didn't like the setup, so try moving it or changing whatever is feeding the signal to it, i.e. cables or receiver.
Dec 18, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
