I need to replace a FAZ12HR2A air/heat window unit. Where can I find one? What is the cost? Unit has stopped cooling!
    Genius:
  • 1,416 Answers
you can order for your air condition part at the below website the prices are different
www.ahamdir.com
www.energystar.gov
www.reviewcentre.com
these site give rooms for competition on there service go on shoping
please rate this solution
thank you for using fixya.
Posted on Jul 05, 2010
I have a Frigidaire heat and ac unit. Model FAZ12HR2A. Fan kicks on but has no heat coming out?
Turn your AC on and see if it is blowing cold air. If it isn't, it is most likely the "blower" that has gone out. Also check the thermostat and try putting in new batteries (even if it appears to be working). Another thing to try is to make sure you have changed your filter. A dirty filter can block the air flow.
Nov 14, 2014 | Heating & Cooling
Ai conditioner compressor will not stop running
I can think of two possibilities. First the main contactor is welded closed and needs to be replaces. Until you call a professional to replace this, turn power off to the entire unit by tripping the breaker.
The other cause for a unit running constantlly, is the unit is trying to satisfy the thermostat and the unit is so undercharged that the unit can not cool or heat fast enough to remove or supply heat depending on cooling or heating mode respectively. Again you will probably need a professional to check your charge.
Hope this helps
Jun 22, 2014 | Goodman CKL49AR49 Air Conditioner
Can a pro recommend a comperable replacement wall AC only-no heat?
Most air conditioners now are reverse cycle, which means that they can heat as well as cool. Cooling only units were popular many years ago due to the price difference for a reverse cycle. Today, the cost of manufacturing has dropped and it has resulted in cooling only units being virtually finished. I would suggest you get a local air con sales company to come to your house to measure up properly and determine what would be best. There are a lot of factors in installing air conditioning. IE/ The size of the house, the area it will be required to heat / cool, the amount of windows, types of walls, roof etc (Heat loading on the house) Roof and wall insulation etc etc.
Apr 09, 2014 | Heating & Cooling
Ac unit will not heat
You need to check your model # a CP06 is a straight cooling window unit you may have an EP08G10 this is a heat cool unit. Double check your thermostat is turned to higher setting. If so you may have an issue with the heating element or the heat limit on the element.
Dec 08, 2013 | Friedrich CP06C10 Wall/Window Air...
How do I fix heat on unit Frigidare Model LRA12HZT2?
There are no heating strips within this unit. This unit has a heater part 5304476390 that you would need to replaced upon a diagnosis.
Dec 24, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
Jun 13, 2009 | Maytag M6X06F2A Air Conditioner
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Open Questions:
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
