Question about Zebra Z4Mplus Label Printer
Z4Mplus doesn't save configuration
Hi, I'm working with a Z4Mplus, but somehow it starts printing the labels incomplete.
I'm trying to change the PRINT WIDTH configuration that is "099 7/8 MM" to "104 0/8 MM", but even if I saved in a PERMANENT way when I print the configurations returns to "099 7/8 MM".
somebody can help me?
  • prix Apr 18, 2008
    Hi lil lil,
    I called somebody who give us support sometimes, he asked me if I had use some label bigger than the ribbon, in fact I did.
    So, he tell me the problem will be that the "print head" is broken.
    you can chek this if you reset your printer:
    1. turn it off
    2. Press pause and feed at the same time
    3. turn it on (still pressing pause and feed)
    4. wait for labels
    5. turn it off again
    6. press pause (only pause)
    7. turn it on, and the will star printing many labels, print just one or tow and see if they are complete. If they are incomplete you have the same problem than me....
    ...but dont worry it only cost 499usd :s
    I'm sorry.. :(
    hope it helps....
I had the same issue.
I'm using the seagull scientific drivers.
It turns out that the printer did not react well to changes made to it through the software.
I deleted the printer and added it again.
I made all my changes immediately through the software (creating a custom label size of 4in x 1in and portrait 180)
My print width setting on the printer is still 099 6/8 but everything prints fine.
Posted on Apr 18, 2008
Zebra Printer prints incomplete Label.
Run a config label and see if you have the same issue. Power it up while holding cancel key is the easiest way to do that.
Oct 28, 2015 | Zebra Z4Mplus Label Printer
How do I configure a Zebrazm4 Plus printer for a
Press the setup button. press next until you get to media type, change from non-continious to continious using the upper config buttons. press setup and next to save permanent. Also you can download Z4Mplus user manual from zebra.com.
May 14, 2010 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Zebra 4MPlus printer erroring
check the driver setting USE PRINTER CONFIGURATION
Mar 17, 2009 | Zebra Z4Mplus Label Printer
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
Oct 14, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
NO COMMUNICATION
hi i have zebra z4m plus printer when i give them command for printing it's not printing and i need a solution can you please help me thankyou
Apr 10, 2008 | Zebra Z4Mplus Label Printer
Printing die cut labels on Zebra Z4Mplus?
Set the printer to transmissivefrom reflective gap sensing.
This will cause the printer to loog for the inter-label gap to tell it where the top of the label is at.
Steve Weinrich
LazerTek, LLC
Dec 15, 2007 | Zebra Z4Mplus Label Printer
Zebra z4mplus printer resets to thermal transfer
Please go to the inhouse program & click printer properties and
change the printer setup to direct thermal and that's it.
Joe
Dec 12, 2007 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
405 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
