Question about LG LSC183VMA Split System Air Conditioner
Air con unit saying 'C6"
Air con unit saying c6 been working fine to date...we dont have a manual
  • 29 Answers
According to the service manuals:
6 is:
Excessive current at inverter
DC power circuit
so the unit shouldnt run?!?
The fault is also coming up as:
indoor unit coil sensor faulty
source:
http://www.mylg.co.uk/data%20for%20site/LG%20Fault%20Codes%20for%20SMS%20%2807%20Sept%29.pdf
all the best
Posted on Jul 05, 2010
My LG split system air conditioner shows C6 in the display of the unit. I can't do anything to get it to function now and even when I swicth the mains power off C6 is still shown. What do I need to do and...
C6-Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor.Thanks, helpful?
Feb 04, 2011 | LG Heating & Cooling
The led panel on the indoor unit shows a C6 error code the air con is a split system plasma inverter
C6 - compressor run current high
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s) , In maximum, it is due to weak capacitor. Replace and try.
Dec 16, 2010 | Heating & Cooling
Replace cover on Bosch Dish washer> Now a C6 code is displayed in the window
I had the same problem after replacing the white panel on my Bosch SHE45M02UC with a stainless panel. I got the C6 error code. I called Bosch customer service twice and neither rep was helpful. One guy told me he didn't know what the C6 code meant. He suggested that I call a local appliance repair guy and he would know what the code meant. I replied, you mean to tell me you work for the manufacturer of the dishwasher and don't know what the error code stands for but a local repair guy that doesn't work for Bosch does?
After all this frustration, I took the panels off and tested the dishwasher with no buttons. It worked fine! Turns out, each identical button isn't identical. Each one is labeled A-G. After putting it back together, no more C6 code! On a side note, try reseting the dishwasher. With the dishwasher on and door closed, hold down the cancel/reset buttons for 5 seconds and release. The disher should drain and reset.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Manual and/or wiring diagram for Nortel's C6 CLID unit.
Hook up orange terminal screws to an available port on KSU
Loop lines from the telco to the first six pairs on the C6 then to the KSU trunk ports.
Software must be DR5 on KSIU to support caller ID.
May 03, 2009 | Lands Phones
Will a ford c6 tranny bolt on to a 1995 ford 5.0l or 5.8l motor?
From 1990-1996 The C6 was replaced by the E4OD which was modified to include a fourth forward speed and electronic shift controls, replacing the hydraulic control mechanism of the C6.
The C6 works fine in your bronco.. Your friend will need a different transfer case!. i dont have the manual but this is my best guess. FOrd likes to make cars that have interchangeable parts. Like a 1999focus can interchange with 2007. as long as the liter and engine size are the same. In some cases. you will have to use different transfercase.
So you might be better off with a c6 transfer case or c4 for your friend.
Hope this helps
Feb 16, 2009 | 1995 Ford Bronco
JVC HX-C6 goes directly into "Protect Mode".
I received a reply promptly from JVC to check power connections for shorts. O course I had already done that. So as a last resort, I pushed the power switch on and held it for maybe 10 seconds. It seems to have reset the unit, and it's playing fine. Best of luck, hope you all read this and it works for y'all. AJ
Sep 26, 2008 | JVC HX-C6 Shelf System
Kyocera Mita KM 1500
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
Feb 08, 2008 | Video Cameras
Making Slimscan C6 work
Your best bet is to go to http://support.microtek.com/ Enter your model number and download the manual, from there you can use the same site to download any software you may need to get things working.
Jul 13, 2007 | Microtek Slimscan C6
LG LSC183VMA Split System Air Conditioner Logo
519 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
