Question about Konica Minolta bizhub C250 All-In-One Laser Printer
I cannot connect to my Bizhub 250's web page on one specific computer in my office.
    President:
  • Konica Minolta Expert
  • 347 Answers
If you cannot connect to your bizhub 250's page then please perform these actions to get rid of this problem.
steps are as follows:- 1-Check that your computer is connected with the machine via network cable. (via Hub etc) 2-if you know the IP adddress of the machine then ping it from your computer. 3-To ping an ip address simple go to "RUN" at the start menu. and type "ping _._._._._,_,_, (ip address of the machine" in the blank you will type the ip address which you want to ping. after entering press "ENTER" if it shows TTL=64, or TTL=32, OK then it means your machine and computer ids coonected with each other. 4-is still webpage is not viewing then install the page scope software or check your connection between machine and computer.
Posted on Jul 06, 2010
My bizhub is printing gibberish when i connect my laptop via office network.
Well if the other computers print ok to the Bizhub its not the machine, copier does not pick and chose which computer will not work. Try this web site for the most up to date print driver
Self Help Product Support Konica Minolta Business Solutions Inc
Sep 11, 2014 | Konica Minolta Minolta Bizhub C353 Copier
We have a Konica Minolta Bizhub 250 at the office and I want to use it as a scanner...I connected the printer to my laptop using a USB cable but it doesnt send the scanned files to my PC. I'm not really...
First of all, bizhub 250/350 is not a single pc scanner.you cannot use it as a scanner by connecting usb cable with it.its a network scanner.so to use it as a network scanner, you have to do these main steps........
1-assign a free ip address to the machine.
2-ping it from the system to check the connection between machine and computer.
3-now, make a scanner one touch account on the machine.
4-enter computer's ip address in the destination option.
5-create a folder on the desktop of your computer and share it.give it full rights.
6-turn the firewall off.
7-enter the folder name which you have made, in the machine.
8-enter user name and password of your computer in machine.i mean while making scanner one touch account.
9-now place the original on glass and scan it........
Aug 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 250 All-In-One Laser Printer: My bizhub c250 is going through a hub to a router....
Type in the ip address of the copier in your web browser. You should be able to log on to the web image monitor and even print a test page. If so you are 90% of the way there. Now go back to the printer setup screen in windows and click on the "port" tab then on configure port. Make sure the port ip address is the same as the copier and make sure the port number is 9100. Keep in mind that the ip address of the copier needs to match the ip address of your network for the first 3 sets of numbers. So if your network ip is 192.168.50.50 the copier would need to have an ip address of 192.168.50.xx
Good Luck and Thank You for using Fixya
May 17, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
How do I print configuration in Bizhub 250?
Touch utility button then on the touchscreen hit in the following order User Settings, printer settings, print reports, configuration page, and the start button
Oct 02, 2009 | Minolta bizhub 250 Black and White Copier
Bizhub 250 error EA3226
Scanner operations
Error Code Cause Remedy
EAXXXX ImageReceiver was not started.
Start ImageReceiver.
The IP address2.gif of the recipient
is not specified correctly in the
dialog box that appears after
clicking “Receive Settings”,
then “Connection Filter”.
Click “Receive Settings”, then “Connection
Filter”, specify the correct IP
address, and then restart ImageReceiver.
ImageReceiver is not operating
correctly.
Restart the computer.
Re-install IP Scanner.
Check the TCP/IP2.gif settings on the computer.
The LAN cable is not connected.
Check that the LAN cable is correctly
connected.
The network settings2.gif on the
computer are not specified
correctly.
Check the TCP/IP settings on the computer.
The network load on the recipient’s
computer is too high.
Check that large e-mail messages are
not being received at the recipient’s
computer and that large files are not
being downloaded from the Web.
Too much data is being sent. If a high scanning resolution has been
specified, reduce the resolution or decrease
the number of pages scanned
at one time, and then scan the document
again.
Access is blocked by the setting
specified for the computer’s
firewall (Windows
firewall) for the Internet connection.
Change the setting specified for the
computer’s firewall (Windows firewall)
for the Internet connection according
to the instructions from your network
administrator.
Jun 24, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Displaying mualfunction detected (bizhub 250)
i will like to know how to reset the page count and service my konica myself, also my konica bizhub 250 is showing C-0204
Feb 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
686 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
