Question about Dell E152FP 15" Flat Panel LCD Monitor
2: digital input self test feature check then red
4 Suggested Answers
fredtmccoyjr
  • 380 Answers
SOURCE: When my turn on my monitor, I get this box that
there are buttons on the front, usually 1 and 2. press one for VGA INPUT. that should do it
Posted on Nov 11, 2009
  • 269 Answers
SOURCE: self test feature check stuck on screen
from my past history dell has/is problems with the E153pc and the E172pb is it under warranty and have you gotten hold of dell about this I have had cases where they have replaced monitors.
sorry it was no great help but dell knows of this problem. dont let them bull**** you.
Posted on Jul 21, 2010
SOURCE: My monitor is stuck on
I'm currently having the same issue, but after some research I have found that it may be that your video cable is disconnected or damage. I hope this helps.
Posted on Oct 24, 2010
Why does my computer have a floating thing that says 3:digital input self test feature check
You monitor is not properly connected to the computer. Check the video output cable and specially, the pins. You may have a doubled pin no making contact
Apr 18, 2015 | Computers & Internet
HDMI to VGA
You need a video format converter to connect in between.
Apr 30, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Oct 27, 2017 | Dell Computers & Internet
My computer is showing a floting box which say self test feature check, wit red,green blue and white box.What do this mean
its showing u monitor self test feature screen issue either with the monitor cable or monitor or the graphic card
Nov 19, 2009 | Dell Dimension 2400 PC Desktop
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell E152FP 15" Flat Panel LCD Monitor Logo
209 people viewed this question
Alun Cox
