Question about Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC
How to disable the right click on my desktop - Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC
Follow this Steps to Disable Right Click
Step 1 :
Click on "Start" and select "Run." Type "regedit" into the textbox and hit "OK." This command will open the "Registry Editor" window.
Step 2:
Select "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer."
Step 3:
Open the "Edit" menu and choose "New" then "DWORD Value." A new file will appear on the right side of your screen with the file name highlighted. Type in "NoViewContextMenu" for the new file name.
Step 4: Double click to open and type in "1" into the Value data box. Hit the "OK" button.
Step 5: Close the Registry Editor by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and you have now disabled your right-click feature
Posted on Jul 06, 2010
Disable internet card
goto --> network center, where you will find the LAN (i.e local area connection) then select the LAN and right click on the icon and select disable. your internet will be disabled.
Jan 25, 2014 | Averatec AllInOne A2 Desktop
How to disable password on Dell Optiplex D170L
Click the "Start" button and then click "Run." Type "Perfmon.msc" (without quotes) and then press "Enter." This opens the Performance window of the System Monitor tool.
Click any of the counters in the right pane that you want to disable.
Click "Delete." This will remove the counter from the System Monitor on your Dell OptiPlex 170L and stop the self-monitoring of that service.
hope this helps
Oct 01, 2012 | Dell OptiPlex 170L PC Desktop
How do i disable the onboard graphics card on the GM5084?
You can go to the devices menu and at the top of the menu screen are two computer icons one is to activate and the other is to shut down or disable it. You can also right click and disable it. Devices is located XP on the desktop right click and go to properties. Select device programs or you can find it on 7 in the control panel.
Jan 30, 2011 | Gateway GM5084 PC Desktop
How do I disable the onboard video card? I have a new DVI card to install in Palvilion a1140n
Hi, you can disable your video card through the Device Manager. In Windows XP, right click on My Computer and select Manage, then double click Device Manager on the left side of the window that opens up. (In Windows Vista, it's called Computer instead of My Computer, but it's otherwise the same process.)
In the Device Manager, click on the plus sign next to Display Adapters to expand that category, and where you see your video card, right click on it and choose Disable. If you later want to re-enable it, just come back into Device Manager, right click on the card, and choose Enable.
Hope that helps!
Oct 14, 2010 | HP Pavilion a1140n (PX774AA) PC Desktop
Cant connect to lan modem
1. check first your lan connections,
click start, go to control panel, click network connections din check your local area connection.
2. right click the local area connection, then try to disable and enable it.
3. if not been solved,
try to look the driver of your ethernet drivers
look at and search your motherboard's brand and model then search it and download for your drivers for your network adapter.
or you may try this,
1. right click my computer
2. click properties
3. clcik hardware tab
4. click device manager,
5. click network adapter
6. right click the name of your network adapter then, click update
Jan 26, 2010 | Gateway 500GR PC Desktop
I would like to create a start point for my computer
The System Restore feature is enabled by default. To disable System Restore:
  1. Right-click My Computer, and then click Properties.
  2. On the Performance tab, click File System, or press ALT+F.
  3. On the Troubleshooting tab, click to select the Disable System Restore check box.
  4. Click OK twice, and then click Yes when you are prompted to restart the computer.
  5. To re-enable System Restore, follow steps 1-3, but in step 3, click to clear the Disable System Restore check box.
hope this helps , if it does please vote
Nov 11, 2009 | E-Machines eMachines Desktop PC
Windows mail 4 vista keeps popping up how do i stop it
METHOD ONE:
Through the Local Group Policy Editor
NOTE This method is only available for the Vista Business, Ultimate, and Enterprise editions. See Method Two below for the Vista Home Basic and Home Premium editions.
1. Open the Local Group Policy Editor.
2. In the left pane, click on Computer Configuration, Administrative Templates, Windows Components, and Windows Mail. (See screenshot below)
3. In the right pane, right click on Turn off Windows Mail application and click on Properties. (See screenshot above)
4. To Enable Windows Mail -
A) Select (dot) Disabled or Not Configured and click on OK. (See screenshot below step 5A)
B) Go to step 6.
5. To Disable Windows Mail -
A) Select (dot) Enabled and click on OK.
6. Close the Local Group Policy Editor window.
METHOD TWO:
Through the Registry
NOTE This method will work for all Vista versions.
Option One: Through a Download
1. To Enable Windows Mail -
A) Click on the download button below to download the Enable_Windows_Mail.reg file.
B) Go to step 3.
2. To Disable Windows Mail -
A) Click on the download button below to download the Disable_Windows_Mail.reg file.
3. Click on Save, and save the .reg file to the Desktop.
4. Right click on the .reg file (on Desktop) and click on Merge.
5. Click on the Run button in the Security Warning pop-up.
6. Click on Continue (UAC), Yes, and then OK when prompted.
7. When done, you can delete the .reg file (on Desktop).
8. Log off and log on, or restart the computer to apply.
Option Two: The Manual Way
1. Open the Start Menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. Click on the Continue button in the UAC prompt.
4. In regedit, go to: (See screenshot below)
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft
A) In the left pane, right click on Microsoft and click on New and Key. Type Windows Mail and press Enter. (See screenshot below)
NOTE: If you already have Windows Mail in the left pane, then skip this step 5A and go to step 5B instead.
B) In the right pane of Windows Mail, right click on a empty space and click on New and DWORD (32-bit) Value. Type ManualLaunchAllowed and press Enter. (See screenshot below)
F) Go to step 7.
6. To Enable Windows Mail -
A) In the right pane, right click on ManualLaunchAllowed and click on Delete. (See screenshot above)
B) Click on Yes to confirm deletion.
7. Close regedit.
That's it,
Hope this helps, Best Regards, -md
Can't connect to desktop
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 06, 2009 | Acer Aspire 5100 Notebook
Wireless switch is disabled how do i enable it?
check "network connections",if youve got the correct drivers for your wireless,you should see the icon,right click it and pick "enable"
you could also right click the icon by your clock to repair,disable.(little tv-looking pikt)
also,you can drag the connection icon from "network connections"to your desktop,it will be a shortcut which will enable you to "double-click"to enable!!
Dec 23, 2008 | Computers & Internet
Remote Desktop Policies
Q: Waht are you wanting to disable the right click for, desktop functions, a specific programs, everything? For everything, a service that throws a journal hook, and swallows all right clicks may be a the ticket instead of policies, then you can apply the service based on who is logged in and deny them rights to start or stop the service. Let me know.
Sep 19, 2007 | Microsoft Virtual PC 7 with Windows XP...
Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
