Question about Toys
I have a 2008 Arctic Cat 366 the starter clutch went bad and I ordered a new one now that I have removed the flywheel and changed this when I tighten up the bolts on the cover the motor will not crank over loosten the bolts it cranks fine
  • 423 Answers
SOURCE: cannot locate flywheel access to remove crank bolt
If you are working on a Mazda Protege, I can help you. I had the very same problem and finally found that there is no "plate" to remove.  There is an open "slot" that you can see from under the driver side of the car, looking to the passenger side very near the center beam at the bottom of the transmission, where it connects to the engine.  Once you find it and shine a flashlight at it, you will see the flywheel.
I had _no_ luck using a screw driver to jam the flywheel gear, I DID have luck using a 1 inch wood chisel, but it is a hassle.
Good Luck!
Posted on Apr 16, 2009
  • 5 Answers
SOURCE: what holds on the flywheel
u will need a puller tool
Posted on Feb 03, 2010
  • 5 Answers
SOURCE: torque limiter gear on electric starter motor is suspect
Go to KTMTALK.COM (free)
This problem has been posted there.
I belive the person had to have the shop
replace some parts for it to work correctly.
It also may have been a missing part. Can't remember but it is there.
Posted on Mar 31, 2010
heimlich
  • 1978 Answers
SOURCE: new 2007 arctic cat 400 4x4 13 miles,backed fired now want star
Take the carburetor apart and clean/ inspect it. It is possible that the slow jet was not put in securely, and dropped into the bowl. just reinstall it. You could have a choke plunger that is sticking open.
Posted on Aug 23, 2010
  • 466 Answers
SOURCE: I need to remove the crank pulley bolt from a
there are several ways i can give more details.
Posted on Dec 31, 2010
What is the valve clearance for a 2008 Arctic cat 366 A2008idg4busg
Intake 0.1016 mm (0.004 in.)
Exhaust 0.1524 mm (0.006 in.)
Mar 10, 2017 | ATVs
Tip
How to chage the belt on anny arctic cat snowmobile with diamond drive
to change a belt on a arctic cat snowmobile with diamond drive. your owner's manual will tell you to use a tool to let the clutch faces separate and so on. there is a much eyeser solution. there is a signal alen key bolt that holds the clutch to the diamond drive assembly. put this alen key in your tool kit and when ever you need to change the belt just undo this bolt remove the cluch from the diamond drive place belt on cluch and with minimal force replace the clutch on the shaft on the diamond drive then tighten the bolt.
on Aug 03, 2010 | Sport & Outdoor - Others
Where is the alternator located on my 2008 arctic cat 700 efi automatic atv
probably has a stator and it'd be on the crank opposite side of the transmission
Jan 11, 2015 | Arctic Cat 2008 700 H1 EFI 4x4 Automatic...
Hard start
Engine seized ?. Will it turn over if you remove the spark plug ?
Here are the service manuals for all Arctic cat ATVs
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
Mar 08, 2014 | Arctic Cat 2009 366 4x4 Automatic
Need the repair service manual for Arctic Cat ATV
You can try to find the repair manual for your atv here: Arctic Cat
Feb 22, 2014 | Arctic Cat 2010 366 4x4 Automatic SE
Arctic How To Install recoil
I assume you mean recoil starter, yes? It can be purchased as an assembly or in individual pieces from the dealer. I checked google and the instructions with diagrams can be found. good luck an be careful if you choose to just replace parts, that spring can be tricky.
Oct 26, 2013 | Arctic Cat 2008 366 4x4 Automatic
2006 arctic cat 650 h1 starter problem? are they
Sounds like starter clutch is binding? Therefore turning starter while riding, then it will melt!
Sep 30, 2013 | Arctic Cat 2006 650 H1 4x4 Automatic SE
Toys Logo
175 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
