Question about Kirby Ultimate G Bagged Upright Vacuum
Shampooing with the kirby
I'm actually trying to shampoo right this minute, but the suds are not even close to what the demonstration did. I'm adding 3 cups of the liquid to the full jar.....what am I doing wrong. I turn the knob to on.
  • Celeste Holmes
    Celeste Holmes Apr 23, 2008
    I figured this out while waiting for the response....but you guys were right, the screen was not in its place correctly. Thank you!
  • Anonymous May 06, 2008
    The manual says to check the shampooer filter. Where is it?
  • 357 Answers
There is a small (approx. 1" in diameter) screen that MUST be fitted onto the hole in the tank that the shampooer hose plugs into. If this screen is not there, the shampooer will not make bubbles. (This is the usual culprit) It can get lodged in the shampooer hose or may be lying loose in the shampooer box. Make sure that the "cup" that you are using to measure is the SHAMPOOER TANK CAP/LID , not the shampoo bottle cap or a measuring cup. Try my online guide to Kirby shampooing..
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps...
Marci
Posted on Apr 21, 2008
    Scholar:
  • 116 Answers
In the cap where you fill the shampoo, make sure the filter and components are clean
Posted on Apr 19, 2008
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
How do you pick up the suds after shampooing
After dispensing the shampoo. You wait a few minutes. Then you turn 'off ' the shampoo picking the shampoo up. After the carpet is dry you pick up the rest. With the power head.
Oct 19, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do I hook up my Kirby Ultimate G for upholstery shampooing?
Hooking up the foaming device simply blows foam into the job. Here is a shortcut which I find more convenient on my G4 tools. If you have the rotary upholstery shampoo kit, you can just attach the rotary tool to your hose. Then mix your kirby suds into a household spray mist bottle. If you happen to have a mist bottle with a screen on the intake straw it will foam your suds not quite as well as the kirby device, but this way you can store the suds in the spray bottle for future quick use.
kirby suds are designed to be used as foam not liquid so a foamer in the spray bottle helps the process. You do not want to soak the furniture, just apply a light mist and scrub with the air driven shampoo tool on the hose. Then allow to dry and vacuum 24 hours later.
Sep 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby not shampooing, no suds coming out.
Make sure the tray is all the way down. Step on the toe petal to adjust. Turn on power assist.Turn sud control valve right to increase suds.
Apr 27, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Shampoo does not sud
The suds screen is not there or is somewhere in hose elbow. Click HERE and read the tip about installing the suds screen.
If you want to see where the screen is supposed to be installed - see out Kirby shampooer manual HERE.
Good Luck
Rocky
Apr 03, 2009 | Kirby G6 Bagged Upright Vacuum
Carpet shampoo system
MY FIRST QUESTION IS WHAT BRAND OF SHAMPOO ARE YOU USING??? KIRBY IS NOTED FOR REQUIRING ONLY, KIRBY SHAMPOO. PART OF THE REASON IS THAT THEY HAVE A UNIQUE FORMULA THAT WORKS SPECIFICALLY WITH THE KIRBY.
THE OTHER POSSIBILITY IS THE DISPENSER IS PLUGGED AND NEEDS A REAL GOOD CLEANING. ALSO, WHEN APPLYING THE FOAM TO THE CARPET, YOU NEED TO GO REALLY, REALLY SLOW.
THE NARROW BAND OF SUDS DOES INDICATE YOU MAY BE MOVING THE DISPENSER TOO FAST. GOOD LUCK.
Jul 01, 2008 | Kirby G5 Bagged Upright Vacuum
Shampoo stairs
There is a portable shampooer/sprayer that attaches to the hose ( the long one that makes the kirby a canister vacuum). It should have come with your attachments. Looks a bit like a gun without the tank attached to the bottom...the tank screws on.
To use it you would put the fingerguard attachment on the front of the kirby where the powerhead would normally go and the hose with the portable shampooer where the bag would go.
The tank on the portable sprayer/shampooer has lines to indicate how much water and shampoo are needed.
Be sure to put the mesh nozzle (sort of a triangular shaped thing with a piece of mesh along the front that attaches to the front of the portable sprayer) on the front of the portable sprayer if you want to shampoo..otherwise it will just spray a mist. The triangular piece with the mesh screen is what produces suds.
Vacuum the furniture/stairs thoroughly before shampooing. Cover the stairs/furniture with a thick coat of suds. Once covered with suds, pop the suds into the fabric/carpet using your hands...working the bubbles into any heavily soiled areas with a soft brush. No need to vacuum after shampooing. There is only about 10 percent water to 90 percent air in the suds.
Then let it dry. 15 minutes to and hour depending on the amount of solution used. Hope this helps!!!
Feb 23, 2008 | Kirby Ultimate G Bagged Upright Vacuum
No suds when shampooing
The sponge filter is in the large opening on the underside of the kirby shampoo tank. It is where the shampoo tank connects to the kirby. The cap the manual is referring to is the shampooer tank cap. It looks like a cup.
If the mesh screen in the hose is in place (try pulling it out of the hose and seating it in the tank where the hose connects.) and you're still having very little suds...(I'm assuming you're using Kirby shampoo as well)...I would suggest going slower when yours "laying down suds". And lower the shampooer head all the way to its lowest setting. I have found if there are a lot of oils in the carpet, the emulsifiers in the shampoo break down quickly and make the suds "disappear".
Be sure to go back over the carpet with the tank in the off position to scoop up any excess moisture. If excessive oil (from cooking, barefeet, and pets are main causes) is the cause of the lack of suds, numerous shampooings will rectify that situation.
Hope this helps!!
Feb 18, 2008 | Kirby Generation 3 Bagged Upright Vacuum
I have a Kirby Ultimate G Series. I have misplaced (no, it's not lost...I have it somewhere) the manual. How do I use the upholstery attachment? Does it hook to the outlet on the shampoo tank?
Hope this helps!!!
Feb 14, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
206 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
