Question about Tvone TV One LM-681M 6.8-Inch Camera Mountable LCD Monitor with AC Power Supply LM681M
Can i do a cable business without any wire (coaxial)? And whats are the procedure, cost, installation procedure etc.
    Guru:
  • 366 Answers
Composite video (yellow, red, & white) forces luminance and the two chromanance video signals into a single signal, destroying the ability of your TV to recover all the original signal information. The result is an inferior picture quality. Coax is by far the better choice.
Hope this helps.
Posted on Jul 05, 2010
I need a longer coaxial cable. How can I connect 2 cables together without a connector?
Ask yourself is the frustration worth the cost of a connector? If not then strip the wires and connect them. You may damage it however you will not have the cost of the connector.
May 17, 2017 | Televison & Video
What are coaxial cables used for?
They are usually used by cable TV companies to connect the user's home or business to antennas and occasionally used to connect telephone lines to telephone poles.
Dec 23, 2013 | Electronics - Others
What are coaxial cables?
Coaxial cables are made of copper and they connect community antennas to antennas in homes and businesses.
Jan 31, 2013 | Electronics - Others
Attaching coaxial cable with rc jack but unable to get any audio video etc from it. doodal
Coaxial cable (like catv wiring) can be used with adapters at each end for RCA connections, however, even if it 'works' the sound quality will suffer, better to get a set of proper RCA patch cables for your connections.
Mar 26, 2011 | Televison & Video
Wireless router will not work without my ethernet cable connected
you need to go into the router settings and turn the wireless on and then it will work
Jan 12, 2011 | Toshiba Computers & Internet
I could not swallow my set up. what to do? how can i assemble tv to a cpu?
Hello and thank you for allowing me to help you.
PLEASE reward the ACCEPTED best answer
******There are several ways to configure your setup, we will cover the most cost efficient way first****
1. You can purchase a TV TUNER PCI CARD or AVG GREEN OR BLACK PORT (SHORTER) to plug straight into your WHITE COLOR slot
2. All you would need is a TV COAXIAL cable to plug straight into the available coaxial cable slot AFTER installing the software
3. You will know that your install went well when you do not receive any errors
4. You will more than likely receive a remote control with your new card
More expensive method
1. Purchase a USB BASED TV TUNER with an available coaxial cable port to plug your cable tv line straight in. This should also include a remote.
Please do not forget to award your ACCEPTED ANSWER
THANK YOU AND PLEASE RETURN WITH MORE QUESTION/RESPONSE REQUESTS
Jan 10, 2011 | ASUS M2N-MX Motherboard
My phone line comes through a cable modem. how do i connect
well no promises but this may work
items you will need
2 coaxial cables
3 way coaxial splitter
1 old phone cable you can sacrifice
soldering iron (optional)
solder (optional)
steps,
take a coaxial cable and cut on of the ends off, throw the severed end away and strip the insulation of the coaxial cable (only strip about 3 inches of it away.
seperate the coper (or sliver wire) from the wire center wire and twist toeghter to make a neat wire
strip some of the insulation away from the white center post revealing the coper wire inside
cut end off phone cable and take about 4 inched of insulation away
5
connect the green wire of the phone cable to the copper outter most wire of the coaxial cable and tape it so that there isnt any of the outer most wire showing
6
connect the white wire to the center wire of the coaxial cable and tape so that there isnt any wire showing
7
connect the coaxial/phone cable you just made to the 3 way splitter
8
connect the coaxial line that comes from your house to the splitter
9
connect the other coaxail cable to the last available port on the splitter
10
connect the non-modified coxial line to your modem/router
11
connect the phone cable to the fax
this might work, no promises, i havent tried it, but it might work and is worth a try
Jun 14, 2009 | Brother MFC-5460CN All-In-One InkJet...
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Convergance/coaxial cables
Check any / all soldered in micro fuses...F851,F852,etc.
Note:read my Powered Products>View all>Toshiba>convergence issues .........? What quality IC's did you use and what price did
you pay ?............................T.
Mar 12, 2008 | Toshiba 50HX81 50" Rear Projection...
Computers & Internet Logo
23 people viewed this question
Top Tvone Computers & Internet Experts
David Payne
David Payne
Are you a Tvone Computer and Internet Expert? Answer questions, earn points and help others
