F 04 on display wont work - Washing Machines
  • tdavidson844 Jul 05, 2010
    Done as you said , found blockage machine now working fine saved me money for nmachine repairs.
    Thanks
    Brigadier General:
  • 4,090 Answers
Error code F04 indicates the pressure switch is jammed on empty.
Remove the lower rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside the hose.
Remove hose onto pump, and check for blockage or obstruction here as well..This should solve the problem.
Please rate my help++++Thanks for using FIXYA
Posted on Jul 05, 2010
Replaced Master cyl, Booster and front calipers, and front brakes are now dragging
replace the rubber hoses to the calipers
it is possible that they are failing internally and not letting the fluid back to the master cylinder
Jul 28, 2016 | Denso 99-04 Chrysler 300M/98-01 Chrysler...
How do I fix fan wont shut off
In front of the 04 code, what is the "F" code is needed for help you. There are 4 different possible answers for this issue.
FAILURE/ERROR DISPLAY CODES Before proceeding with any corrective action, perform the following steps to enter the Diagnostics mode: 1. To recall last failure code, if not displayed, press the Cancel key to place the range in an idle state. 2. Press the Cancel and Start keys in the following order: CANCEL, CANCEL, START. 3. Verify the error code displayed on the control by observing for longer than 1 minute. If the error returns, use the applicable procedure listed below for the actual error code that is displayed.
With this information, I can narrow down the cause and possible repair on you unit. Thanks
Apr 11, 2016 | KitchenAid Kitchen Ranges
How can i open my Nokia c5-04
Warning: Do not enter any wrong unlock unlock codes on your Nokia C5-04 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia C5-04 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C5-04.
3 - Compose #pw+CODE+1#.
4 - The Nokia C5-04 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C5-04 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C5-04
Each Nokia C5-04 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia C5-04 mobile phone atwww.mobileunlocksolutions.com.
Apr 20, 2014 | Nokia C5 Cell Phone
Car wont start
but cranks ok, right>??????????????????????
green key, in display,
my guess, you never read the manual> ever>?
if answer this,
here it , is
ahh no 04 here.
so read 01, or 08 ,id bet the green lamp means same thing...
(server is slow,) and folks are off work today. soooooo
http://justgivemethedamnmanual.com/honda/
IIRC:
the green key means IMMO very unhappy
so did you try (only no rings or other keys) the IMMO master key
the car comes with 2 keys,. never lose both.
IMMO= immobilizer, engine cranks but fuel is cut , IMMO doing its job.
Dec 30, 2013 | 2004 Honda Odyssey
Vfit pst 04 problem ---- (dashes) on display
1) you must replace the key by smal magnet, since the key is magnet, you can buy from any Hardware.
2) Adjust the reed switch, see the diagram, clean, tight the connector very well.
God bless you.
May 14, 2012 | Exercise & Fitness
Konica 7255 diaplays a F56-04 code when IP is installed
That is correct. The IP511A is for the 7255 / 7272, and the IP511 is for the 7155 / 7165.
This is probably due to these machines using different image processing boards.
I am actually surprised it lets you get as far as you did with it.
Feb 08, 2008 | Office Equipment & Supplies
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
