Question about Rockford Fosgate Punch 500a2 Car Audio Amplifier
Fried 3 amps. Is it my car? 93 mustang gt. I had my original amp Rockford Fosgate punch 500@2 for about 8 years then the whole system got stolen. Bought the same one on Ebay and it was fine for a few months then one channel went out. A few weeks later channel 2 went out. I had a punch 200#4 for the interiors that went out around the same time. The 200@4 wont power on anymore. I replaced the 500@2 with another Ebay one, worked fine for maybe 2 weeks then it started popping while the radio was turned off. I tested the amp on wire and it did not have power with the radio off so I dont know how it was popping, but it was loud. Now the amp wont turn on at all. I tried running the amp on wire directly to the 12v, tested all powers and ground but it wont power on at all. Do I need to stop buying amps on Ebay? Or could it be something in my car's electrical system? Maybe a spike or a short? If I bought a capacitor does it even out the voltage?
  • 733 Answers
Make sure you run your ground and power wires on one side of the car and the rca's on the other, keep them sepparate. if you have all wires running to your amp(rca's/12v power/remote), then you run the chance of either getting interference from the alternator, or if you have a pinched wire(usually by the door step) it may short with your battery wire. Double check your rca's and make sure they're ok and also check for corrosion on your wires.
Posted on Jul 05, 2010
Testimonial: "Thanks that explains why when it was working I could hear the engine noise through the subs. I had them all running together. I will re-wire it all. Thanks a bunch."
  • Rockford Fos... Master
  • 637 Answers
You mentioned that the whole system was stolen. My question to you is did you replace any of the system wiring that originally was in the car? Please understand that when thieves steal they don't exactly take their time and leave your stuff in a very nice manner. if you do not have your RCA and speaker wires on opposite sides away from where your power cables are you will definitely pick up noise off of your alternator through the lighting electrical system. you could easily have a short in your r_c_a cables where they pulled or strained as they were taking your first equipment. Cheaper to replace cables than major audio components.
Posted on Nov 21, 2014
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
  • 82 Answers
SOURCE: No end caps,what are they
The end caps screw on to both ends to hide the cables and wires. Not required unless you don't wat to see any wires in a surface mount type install. Does not affect performance
Posted on Apr 29, 2009
  • 182 Answers
SOURCE: Rockford Fosgate Punch 800 A2 shorting out.
replace the inputs on ur amp
Posted on Jun 29, 2009
bill_48632
  • 149 Answers
SOURCE: connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Posted on Aug 09, 2009
Professor_V
  • 92 Answers
SOURCE: Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
Posted on Jan 06, 2010
How do u bridge the rockford fosgate p325.1?
Hello... sorry you are having a problem. If you are running the 325.1, that amplifier is strictly a mono-block amplifier (1 channel) so it is not possible to bridge it. There are 2 speaker connections on the amp but both positives and negatives are connected on the circuit board in the amp. Hope this helps. Good luck with your venture.
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Rockford Fosgate Punch P325.1 Car Audio...
I have a old 2001 rockford fosgate 2 channel p5002 model in great condition just need to know how many watts is it and which subwoofers are compatible to this amp? thanks
Your amp is rated at 500 watts. Here is the break down of your wattage.
125x2 at 4 ohms
250x2 at 2 ohms
500x1 at bridged 4 ohms
When hooking up the amp make sure to use 4 gauge power and ground wire.
Jan 07, 2011 | Rockford Fosgate Punch P5002 Car Audio...
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
I need to wire up a rockford fosgate punch hx2 12" subwoofer to a 500 watt single channel amp and i need to know how to wire the dual voice coil properly ??
Wire it in a series. One wire from amp positive to one positive speaker terminal. One wire from amp negative to negative speaker terminal. This should leave one positive and one negative termianl on the sub. Use one additonal wire to connect these two, this wire should not be connected to anything else other than the two remaining terminals. This will allow you to have the music up louder with higher amp settings without having to worry about blowing the speaker as easily.
Jun 24, 2010 | Rockford Fosgate Punch HX2 RFD1212 Car...
Rockford Fosgate Punch 500a amp wont turn on
check the internal fuses inside the amp its self these burn up real easy plus if it is them it will save you some money
Mar 31, 2010 | Rockford Fosgate Punch 500a2 Car Audio...
I'm looking for a wiring manual for a punch 150 amp
Follow this link to the downloads page for Rockford Fosgate, you can choose the correct manual there.
LINK
Sep 25, 2009 | Rockford Fosgate Punch 150a2 Car Audio...
Connect rockford fosgate amplifier & speaker together
Aug 09, 2009 | Rockford Fosgate Punch 401S Car Audio...
I get a better sound with my 250.2 than with my 500a2
Rockford Fosgate was bought out over 10 years ago. the amps you have are from that era. Its probable that the 250.2 was made before the change over, and is just a better quality amp. the a series amplifiers were some of the first produced by the "new" Rockford Fosgate, and they sucked, along with most of their products since.
Aug 07, 2009 | Rockford Fosgate Punch 500a2 Car Audio...
Rockford Fosgate Punch 500a2 Car Audio Amplifier Logo
193 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
