Question about Logitech Cordless Mouse
My mouse has stopped working. Are there batteries in it?
The mouse has stopped working. I put new batterie...
the gear head wireless mouse i purchase for my netbook, does not work
May 20, 2010 | Apple Mouse
Why did my wireless mouse stop working?
check if the battery of your mouse is out of power. and if it is out of power replace the battery and clean its sensors from the mouse.
May 09, 2010 | Microsoft Wireless Laser Mouse 5000
My logitech wireless mouse stopped working. I
Turn the mouse over. There is a battery cover that needs to slide to open. Your mouse should take 1 AA alkaline battery. Also there is a recesssed button on the underside that you you can press (with a pen tip or paper clip to reset the mouse). Either the new battery or the reset should solve your problem.
Please rate this solution. Thanks.
Apr 22, 2010 | Logitech Cordless Mouse
Wireless mouse stopped working. green light works
This can happen when the battery's are starting to die. Replace the batteries and then test the device again.
Oct 09, 2009 | HP Wireless Optical Mouse
Mouse has stopped working. Batteries renewed -no
two thing with this mouse
1. Flashing red usually means its not connecting to the base
2. rare case the mouse has gone bad needs replacement
Aug 10, 2009 | Logitech Cordless Mouse
Laser mouse stopped working
your mouse laser is damaged. please replace your mouse.
Jul 31, 2009 | ACCO Brands Kensington PilotBoard 64390...
Wireless mouse stops working
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver burron and then press the button on the mouse. This should be fdone when ever you change batteries or glitch. Hope this helps you. Bud
Dec 30, 2008 | Computers & Internet
Mouse only works for a few seconds and then stops.
have you changed the batteries recently? Wireless mice seem to eat batteries faster. I have a Dell wireless mouse. It will work fine for months and then nothing. That's when I know to change out the batteries. If your batteries are fresh, make sure they are seated in their slots securely.
Dec 02, 2008 | Belkin F8E825 USB Mini Wireless Optical...
Dell wireless mouse
I had this problem, but only when my batteries were dead. Check the contacts on the batteries to make sure they're working. Are all the buttons failing too? It might be a broken microswitch (or whatever they use these days). It sounds like you're looking at a new mouse if it's not contacts. Unless someone else on this forum has different ideas.
Nov 04, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Logitech Cordless Mouse Logo
77 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
