I added a computer and secured it my other computer wasnt secured and it got disabled and wont connect. the one i added works fine?
    Champion:
  • 200 Answers
You now have a secure network be sure both computers have the same workgroup name if both are wireless you will have to change advanced settings to secure on the wireless properties of the first computer.
Posted on Jul 06, 2010
Cannot connect to google chromeinnternet
- Disable Sandboxing Mode.
- Check if Incognito Mode Works Fine.
- Disable Ad-Filtering Programs.
- Repair Chrome Registry With Reginout.
- Remove Chrome Default User Profile.
- Disable Integration with Download Manager Programs.
- Disable Integrated Version of Shockwave Flash Player.
Oct 31, 2013 | Computers & Internet
Iphone 5 has been disabled and forgotten passcode
iPhone Is Disabled After a series of more failed attempts, your iPhone displays the same "iPhone is Disabled" message, but with an added "Connect to iTunes" message. At this point, your iPhone shuts down completely and you cannot make any more attempts to enter the passcode. In order to restore the device at this stage, you need to connect it to a computer with iTunes installed. Ideally, connect it to a computer that you've used before for syncing your iPhone.
Apr 08, 2013 | Cell Phones
Acquiring network address
all that you need to do is to delete the preferred networks list from the computer,
and try to scan and connect to the network again....make sure that you are typing the correct security key.
still if the problem exixts, then add the network manually...the problem will get off for sure....
also if there is any facility like wi-fi protected security is enabled in the wireless router, go ahead and disable it...
Apr 03, 2010 | Linksys WRT54G2 Wireless Router
The internet was working, we turned it off because we were told to by itunes, as we were installing itunes for a new ipod. We turned it on again and no internet working, and the signal sign on the laptop...
The firewall is blocking the connection. Turn off all computers. Turn off router and modem. In this order, turn them all back on. First modem, wait one minute. Next router, wait one minute. Last, all computers. You should have connection now.
Oct 04, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
No wireless adapter detected ad wireless button ot turning on
First u need to make sure ur adapter is installed correctly.
1. Click on Start-->Run-->Type in "devmgmt.msc"
which will open device manager.
Under device manager , u should find network adapters, make sure ur adapter is listed under it without any yellow exclamation mark or red cross which would mean that the drivers are not installed correctly or the adapter is disabled. In this case u need to reinstall the drivers via the CD.
2. Secondly u need to goto start-->run-->type in "msconfig"
which will open the system configuration window. Now under the "startup" TAB. Find the service for ur wireless card and disable it by unchecking it and then apply the settings and OK.
Reboot computer once
3. After reboot, goto start-->run-->type in "services.msc"
It will open the services windows . Find an option for wireless zero configuration . Rt click on it and start it.
4. Goto start-->run-->type in "ncpa.cpl"
It will open network connections window.
Rt click on Wireless network conection and enable it .
If it is already enabled , then rt click on it again and click on "View available wireless connections"
It will give u a list of all the wireless connections available in ur area.
Click on the one which is ur connection and then click on connect.
It might ask u for a wireless key if it is a secure connection. Enter the key and it should all work fine.
May 25, 2009 | Acer Aspire 5520-5579 Notebook
Vista ultimate 32 not connecting to wireless
169.254.x.x IP suggests that your NIC is not communicating with the DHCP server of your Router. Try disabling/enabling the NIC card and in the TCP/IP properties, make sure that the IP address is configured as "Bobtain IP address automatically"
Also try installing the latest drivers for your NIC card.
May 13, 2009 | Trendware TRENDnet 4-port Switch - 54 Mbps...
Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
May 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless Networking - 2 PC's
ai..McGuywer,
on St. Paddys day and nice to ya.
you'll need a router, maybe you can track down a good one here, where we list the best three?
Mar 18, 2008 | HP Compaq nc6320 Notebook
Unplayable songs
Disable auto-sync option
Sep 17, 2007 | SanDisk Sansa e250 MP3 Player
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
