Multimedia Projectors
Problem for Multimedia Projectors
Generic problem for all Multimedia Projectors
Panasonic PT L501U Projector
By fccanova1973 on Apr 17, 2008
Ok all the fans are running... lamp is striking and then green LED blinks and then goes orange and the lamp shuts off, then goes into cool-down and after that goes into standby LED red... then does not recover unless power off then on.
If it was a power ballast issue, the lamp would not light or would arc or blow... what else do I look for or you suggest....
I appreciate your help
Same Problem
Aug 13, 2008
-   I have the exact same problem. Does this mean i need to change the power supply?
-   Guest
Solution #1
posted on Apr 18, 2008
Not Rated)
Marrie
Rank: Guru
Rating: 86%, 448 votes
Right , if the indicator light goes from Green to Orange when shutting down , it will be the Powersupply that is giving problems and not the Ballast.
Was this helpful?
Yes
No
Popular Solutions for Multimedia Projectors
Questions and Unsolved Problems for Multimedia Projectors
Answer
High picture quality durability bulb life time and sound quality etc.More conserned.
Answer
Looking for 3-d projector for an art classroom. I need a simple easy to use projector. thanks
Answer
How do i replace the bulb in my sanyo proxtrax projector. I have lost the manual.
Answer
How to reset lamp counter in Sony-VPL-ES3
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Multimedia Projectors:
Top Multimedia Projector Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Multimedia Projector Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
