Question about Garden
On a vermeer 625BC the auto feed stopped working after a shutdown. Restarted it and no feed at all unless i unplug the 2 wires on the magnetic selinoid that supposedly is part of the auto feed.
2 Suggested Answers
  • 54 Answers
SOURCE: the auto feed on a 625 works then it dont, I
I had a 625 chipper several years ago with the same problem. It was just that the engine rpm was to slow sometimes. I don't remember exactly what it needed to be but I think it was around 3500 rpm.
Posted on Dec 11, 2009
Used Vermeer sc252 stump cutter. Just purchased and testing. During operation it sometimes jumps forward pulling into the stump and stops from too much feed.
I tried the service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
Mar 22, 2018 | Heavy Machinery
My NordicTrack x9i will not recognize the magnetic safety key - it was working fine and now nothing? any ideas?
The magnetic read switch is faulty . You have to replace the reed switch.If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.com/
Nov 01, 2016 | NordicTrack Exercise & Fitness
How do you change oil in a Vermeer feed roller
I would google the unit model number for oil change instructions, since I don't have the model number I can't do it.
Dec 31, 2014 | Heavy Machinery
Vermeer 252 wiring diagram
I need a wiring schematics for a 352 Vermeer stump grinder
Jan 14, 2013 | Vermeer 2006 Sc252 Stump Grinder
Treadmill won't start. Console works but when push start or any of the buttons it beeps and nothing happens. It incline, change speed. I unplugged and restarted but nothing.
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
11_21_2011_11_34_59_pm.gif11_21_2011_11_35_24_pm.gifRemember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
Oct 29, 2011 | Nordic Track C2255 Console (treadmill)
I have a Freespirit Treadmill...Model l# JM05-001. I was using it and it just shut off giving error message E1. I turned it off and restarted it. Belts are working fine and did not use incline. It runs...
Don't laugh, but I'm working with an old Athlon Simplicity model to try and adapt the motor to a band saw. In any event. There is a magnet imbeded on the outside of the front belt roller. It triggers a circuit that counts the revolutions. There should be a small postage stamp sized black plastic piece near the belt roller that has two wires running to the circuit board. It may have come unplugged somehow. When I unplug mine - the motor stops and it displays E1.
Jan 15, 2011 | Sport & Outdoor - Others
1993 jeep laredo auto shutdown& fuel pump relays go crazy open & close it wont stop and car dont start
Most often a relay will act like a buzzer if it is not properly grounded. The ground signal generally comes from the computer. The auto shutdown realy feeds the fuel pump relay and therefore is shutdown relay isn't getting the proper signal it will in turn send same improper signal to pump relay. I am sending you a decent diagram of this and suggest you first make sure all body grounds are clean and secure.
http://www.scribd.com/doc/18999822/Jeep-Wiring-2
Dec 09, 2009 | 1993 Jeep Grand Cherokee
The auto feed on a 625 works then it dont, I
Sep 25, 2009 | Garden
Thinkpad R60 auto-restarted when shutting down
try pulling the battery out for a day running on ac only
Jan 06, 2009 | IBM ThinkPad R60 Notebook
Garden Logo
435 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
