Question about Garden
I have a Homelite Chainsaw 45cc Power Stroke. Model No. UT10946D. The chain brake is always applied. Brake lever will not latch in the released position. I've disassembled it and do not see anything physically wrong. Defective latch maybe?
  • danebo Nov 20, 2013
    I also have the same model & same problem, replaced brake band & drum thinking they may be distorted from the heat - no change. Contemplating removing brake band and just using inertia brake, however, not safe but still renders the chain saw useable since it's almost new.
I have the same model (ut10946d) and used it for less than 2 tanks of gas when the chain froze. I noticed it was slowing down and it seemed like the chain brake was not disengaging and staying in the "unlocked" position.
I took the tool apart today and found that the band that rubs on the clutch to stop the chain was dragging on the clutch because it doesn't disengage all the way. The heat from the friction melted the plastic parts around the clutch housing and crankshaft. So now I have a chainsaw that I bought new, used for less than an hour, and is now junk due to poor design and/or product control.
I WILL NEVER BUY ANOTHER HOMELITE GAS POWERED TOOL AS LONG AS I LIVE. THEY ARE PURE JUNK!
My solution, call homelite and complain about it, maybe they'll stand behind their design flaws - but I doubt it.
Posted on Jan 28, 2013
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
  • 4088 Answers
SOURCE: Need replacement Chain oil pump
Go to the Homelite web site, which will get you to HCPI Electronics Parts catalog. You will need the model number. The parts are illustrated as a break-away drawing for various portions of the saw. Hope this helps.
Posted on Sep 01, 2009
  • 4 Answers
SOURCE: Does anyone know the carb. setting for a Homelite
Most of the newer saws don't have a rich and len ajustment on the carb.....it could be durty air cleaner....or you may need to get a rebult carb.
Posted on Dec 29, 2009
SOURCE: Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Posted on Feb 14, 2010
dontbother10
  • 2220 Answers
SOURCE: set carb homelite chainsaw mod ut 10939
No response to CR.
Posted on Mar 13, 2010
What is the chain brake an where
not on the older chainsaws
newer ones it s normally the black lever you hold
Check the Chain Brake
Make sure the chain brake is working properly by putting the chainsaw on a stable surface. Release the chain brake, squeeze the throttle and then activate the chain brake by pushing your left wrist against the kick back protection without releasing the handle. This should cause the chain to stop rotating immediately.
source
http://www.tractorsupply.com/know-how_home-garden_outdoor-power-equipment_chainsaws_the-basics-of-using-a-chainsaw-for-beginners
can be part of the centrifical clutches
Apr 30, 2016 | Garden
Looking for homelite model 3374 chainsaw
Pull the handle back to free position.
Jul 12, 2014 | Homelite Garden
Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Jun 25, 2010 | Echo CS400 18" Chain Saw
Aug 29, 2009 | Garden
I can start up the chainsaw, but chain doesn't spin
Is the chain brake on? Pull the lever your knuckles are against toward you to unlock the anti-kickback brake.
Jun 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Ryobi gas chainsaw- chainsaw brake is stuck on. How do I release
You just have to pull the lever back, like it was on the saw, until it clicks/unlocks. It may be hard to do, but thats what has to be done.
Jun 11, 2009 | Ryobi Garden
Is it possible to adjust the chain break & how to do it.
hate to say this,but,there is no way to adjust the tension on the brake band.either the spring is weak or the brake band is broken.either can be changed but it's not easy.spring is under a lot of tension and can fly out when taking it apart or installing,you can get the entire cover as a unit if so desired...hope this helps,let me know
Apr 21, 2009 | Garden
Ryobi pcn3335 chainsaw chainbrake will not release fully
1. Is there a Homelite/Ryobi dealer/authorized repair facility near you? If yes I'd try them they may repair it.
2. Any major chainsaw seller/repairer may be able to repair it... there will be a fee.
Lou
I own a few chain saws without chain brakes. I also own and use good PPE.
Feb 25, 2009 | Ryobi Garden
Chain brake will not release (homelite chainsaw)
The header says you have a Homelite saw and if this correct you can go to Homelite.com and look up parts or other information that you might need for your saw. There is also a contact us area. Good luck
Jan 25, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Fix bar brake on homelite timberman 45
It's a design flaw in timberman chain saws. After some hours of use, they develop a bad habit of not releasing the clutch drum completely. And that takes precious power away from the saw. If it becomes too tight, the clutch drum may over heat and cause the plastic enclosure to warp or melt down. After messing with this brake for months, I ended up completely removing it. Replacing it was not an option for me - there was nothing to replace - it is not the brake band that's bad, but the mechanism in the brake handle of this saw that is flawed. Overall, this chainsaw is very cheaply built - Homelite used waaaay too much plastic in it!
Oct 12, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
695 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
