Overheating laptop hi. i own a presario m2000notebook and it overheats and shutdown in less than 1 hour. how may it be fixed? also, the keyboard'sbroken, i can't use some keys. could it be that the keyboard is just dirty? thankyou
  • radman53 May 24, 2008
    I have a HP dv 4000 laptop that overheats after 30 minutes and shuts down, What screws on the bottom do I unscrew to open it up and clean out the dust bunnies?
    Scholar:
  • 144 Answers
What you have to do it..open up and clean the fan or cooler inside..I think the flow of air is being blog by dirt.You can test by
putting your hand next to the flow of air at the side of your notebook and see that the flow of air is strong or not.Most cases
is the problem I mentioned above.
Takecare.
Posted on Apr 18, 2008
Continue reboot loo
There are a lot of possible reasons for this.
1. Fan is bad.
2. Motherboard has gone bad.
Do you still see the Compaq logo when you turn it on?
David
Jun 10, 2013 | Compaq Presario 700 470024-192 Notebook
I can't able to download file or view file from internet.as long as i start it my laptop automatically shutdowns.plz guide.
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Jan 07, 2013 | HP Compaq Presario v3000z Notebook
I replaced the internal battery on my cq60 and it's been 3 days and the same warning messge is back. Any ideas what is wrong?
HP laptop appear error message during the booting such as wireless 701, coms, keyboard LED blink, shutdown etc. you may try to update newly bios version first. it could be fix:
1) download new version bios at HP support,
2) run its for windows version at laptop windows if laptop booting in windows well
3) run its DOS version at winpe which boot at DVD if laptop could not come in windows itself.
if it is not fix, it is could be SB bridge issue, at most AMD SB+NB bridge.
Oct 17, 2012 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
Thinkpad A22m 2628-3SU laptop premature shutdown
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 18, 2012 | IBM ThinkPad A22m 2628 Notebook
It is been 1 year that I bought my laptop.I have Toshiba A665-s6065.when I use it for some hours in normal cases(internet,movie,...),Toshiba health monitor shows me that my CPU temperature is going up and...
Hi RGH.
1. Fix Internal Cooling. The first and most important thing you need to do when your laptop is overheatingis to clean the fan(s) that provide(s) cooling to the CPU and graphics card. Over time, they build up layers of dust and dirt that slow them down and block airflow.
How to Fix an Overheating Laptop - MakeUseOf.
What can happen to a laptop if it overheats?
A laptop that severely overheats causes damage to the internal components. Before this happens, the laptop should attempt to shut itself down. ... If you smell smoke, a burning odor, the fans never run or the fan runs all the time, be careful to avoid ruining your laptop.
Negative Effects of an Overheated Laptop ' Chron.com.
How can I stop my laptop from overheating while playing games?
Maintain a cool environment.Try keeping your laptop in an air-conditioned or cool area to allow your system to cool down and prevent it from overheating. Consider using a heat sink. Use a steel flat bar as an external heat sink. It works because your computer has to heat up more mass before it overheats.
3 Ways to Keep Your Laptop from Overheating - wikiHow
HOPE THIS HELPS YOU OUT.
Nov 04, 2017 | Toshiba Satellite A665S6065 Notebook
I have a Compaq Presario F572US to which turns off on occasion and tries to reboot but fails. I then take a blow dryer to the heat sink side for a couple of minutes and will come on and work again for...
If your computer occasionally shuts off it may be due to overheating. As a safety precaution your computer will shutdown upon reaching a certain temperature. If you are using your laptop in bed, and it is resting on a blanket or some other object is blocking the fan it may cause the laptop to overheat. Try elevating the laptop or getting a laptop mat with built in fan to help keep it cool. If there is an issue with the Nvida card changing the BIOS will not help.
Mar 16, 2011 | Compaq Presario F572US Notebook PC
My laptop is overheating and the fan is always on making a hissing noise,its a compaq presario cq40
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Jan 05, 2011 | Computers & Internet
I have a compaq presario f700 and it never overheated until one day i played a game on ninjakiwi.com called SAS zombie assault 2. Now when i listen to music on windows media player or watch videos on...
Insufficient information, but try this for starters:
Make sure the laptop sits on a hard surface and the fan vents are not covered/clogged.
1) Run windows only on a fully charged battery and see if it overheats
2) If not, run media player only, and look for the same
If it overheats in either step, you have a hardware/software problem.
Hardware problem could be that the fan has failed completely and needs to be replaced.
Software problem could be incorrect fan settings, although I do not think you can turn the fan OFF on a laptop.
IF the laptop overheats in Step 1, I would definitely suspect a hardware problem. In that case, run the laptop but do NOT log into windows. Go into the BIOS (check fan settings in there, if there are any).. leave it running in BIOS and see if it overheats then.
Aug 18, 2010 | Computers & Internet
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
271 people viewed this question
David Payne
David Payne
