Question about Leviton 003-1755-W Three Rocker Switches
Am doing a 'remodel'. Discovered the 2 lights in
Am doing a 'remodel'. Discovered the 2 lights in the basement (3 way switched) received their power - from a wired outlet.
Outlet has been elimenated. Installed 'Junction Box' ran the power wire, and both switch wires plus the remaining branch of existing outlets.
Have not hit upon the right combination of wires to get both 3 way switches to work. Have not triped a breaker as yet, nor lit up my eyes. I know it is not rocket science. 3 ways always give me trouble. Help!
Email address - CaptMikeG@msn.com
    Novelist:
  • 145 Answers
Well you have to make sure of three things with three way switches...where your power comes in, where your power goes out, and that your travelers are not mixed up. Lets talk about a normal three way circuit. Power comes in to your first switch. You attach your power wire to the common terminal, usually a different color than the other terminals. The other two are your travelers, if your switches work partially you probably have these mixed up. The color traveler you have on one switch terminal has to go on the exact terminal on the other switch. Also check that your neutral is not swapped with a traveler, this will cause your eyes not to light. In between switches there is most of the time three wire cable (2 travelers and a neutral---while two wire cable is used before the switches and after it going to the light). The power then goes out of the common terminal of your second switch. If all wiring is good, I would take your switches out and check them with a continuity tester to see if they are bad. Check continuity on each switch between the common and each traveler terminal.
Posted on Jul 05, 2010
I was offered an electric stackable Frigidaire stackable washer/dry GLET1031; the catch is that it has to be separated to get it out of the basement due to the stairway. Can they be separated? How?
Normally there are 2 brackets joining the two machines at at the back that have to be removed. Then if there looks like a collor around the join of the two machines then you need to lift the top machine by a few inches to remove it from the machine.
Sep 30, 2014 | Frigidaire GLET1031 Top Load Stacked...
Can anyone recommend any expert basement remodeler of North Virginia?
Basement Remodeling Northern Virginia experts are dealing in North Virginia and you can hire them as they are expert in custom deck building.
Aug 28, 2013 | Victory 2005 National Renovation &...
Im taking out a switch in a four switch circuit
If you are planning to put 4 switches back in after the renovation, you need to make a wiring schematic of exactly how they are wired now and label each wire according to your schematic. Then when you put them back, everything will work. If you are going to use less light switches then the schematic will help with a smaller number of switches. These are 3-way switches, for your information, not regular 2-way switches!
Jan 02, 2013 | Dryers
I remodeled my kitchen and replaced my leviton dimmer switch with another brand. After installation I turned the light fixture on. Only one of the three lights of the single fixture turned on for...
Hi Leonard,
I'm a licensed electrician and will be happy to help you get this working again. I suspect an incorrectly wired or incompatible switch or a load that is not designed for dimming. To know which one(s) is the problem and to be able to provide a solution, I need a little more information.
1) What was the old switch brand and model number?
2) What is the new Leviton switch's model number?
3) What type of light bulbs are you trying to operate in the 3 fixtures?
4) What is the number of and wattage of each lamp in the fixtures?
5) How many switches operate the lights?
5a) If more than one switch is used, what is the brand and model number of the other switch(es)?
Thanks
Oct 05, 2012 | Electrical Supplies
2 switch system. 2 black wires and 1 red wire in the switch. I have hooked up black wire from the switch to the red wire in the box. green wire from switch to black wire from the box and red wire from the...
You posted under ST01C and are wiring timer to replace 3-way switch.
Open following link for specific illustrations:
http://waterheatertimer.org/ST01C-program.html#ST01C
http://waterheatertimer.org/pdf/ST01C-explanation.rtf
1) The timer replaces one of the 3-way switches. The other 3-way switch remains, but must be rewired.
2) The timer must replace the 3-way switch that receives power from breaker box. It cannot replace the other 3-way switch. This is because the timer Black wire must always receive power.
3) The timer blue wire must connect to Load (light)
4) The ST01C red wire is only used when wiring for 3-way.
5) When the red wire and blue wire are connected together, they reverse the timer program. When timer red and blue are disconnected, the timer resumes programming. Connecting and disconnecting the red and blue wires is how the timer mimics 3-way operation.
6) The remaining 3-way switch must be wired so it will connect and disconnect the red and blue timer wires. So the remaining 3-way switch has to be rewired to meet specific timer wiring.
Jul 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
We installed a 27185 remote kit in a hunter fan, and factory settings. The fan light goes on and off by itself. I changed the dip switches( matched them to the remote to the controller), and the fan and...
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
Jul 09, 2010 | Hunter 27185 Remote Control
I have power running to a 2 switch gangbox. Each
As long as the power is running from the breaker panel to the switches rather than the fixtures then it should be pretty simple.
1. Run a new 2 conductor wire from the existing box to the new box at the top of the stair.
2. Install a switch at the top of the stairs.
3. Disconnect the hot wire that is running to the two existing switches and connect it to one of the two conductors running to the top of the stairs.
4. Connect the remaining conductor on the wire going to the top of the stairs to the two existing switches.
Note that if you want to be able to use the Dimmer function from the top of the stairs this will be much more complicated. You will need to put two new switches at the top of the stairs, run more wire, the new switches will need to be 3 way dimmers and the existing switches will almost certainly need to be replaced as well. The wiring will also be much more complicated.
Jan 09, 2010 | Lutron Claro Screwless 2 Gang Wall Plate...
My 1/2 HP WaterAce sump (R5S-1) runs but will not shut off
I found a replacement switch which is placed in series with the pump power plug. However when I removed the original switch and plunged the new switch I discovered that the pump motor spins but it does not pump. I installed a new pump.
Thanks!
Jun 19, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Receiver does not power on
have a tech check your set your your power is deffected.good luck
May 02, 2007 | Samsung SIR-TS160 DirecTV DTV Receiver
Leviton 003-1755-W Three Rocker Switches Logo
115 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
