Question about NEC LT 260 Multimedia Projector
WHEN POWER ON PROJECTOR DOES NOT ON WORK - NEC LT 260 Multimedia Projector
  • 45 Answers
Do you get lights? are they blinking? The number of blinks will tell you what is wrong if you go to the manufactures site and pull up the manual. (It may be a combination of lights instead of blinking lights)
Check for:
Bad bulb-check to see if the little wire inside is whole, just like in a lightbulb, look for cracks near the base, or any other sign of breakage.
bulb- inserted improperly?
All panels and doors must be on, and the screws in, for most projectors to do anything..
Check the cord, you should get at least one light if the cord is good.
Posted on Jul 05, 2010
Why does the orange power LED blink?
hI,
After pointing the remote to the projector Press and hold the "Help" button on the remote control for 10 seconds or more. And the power on the projector .
www.electro-medical.blogspot.com
Aug 29, 2015 | NEC WT610 DLP Projector
Runco CL710 projector. Had power outage and projector won't turn on. Project was plugged into surge protector. Surge protector is working, green light is on. Checked all electrical breakers, they are...
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video for this.
Aug 25, 2013 | Runco CL-410 Multimedia Projector
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
procedure:
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
This projector was given to me by a friend. The control buttons on the top of the projector do not seem to work. The projector seems to work fine otherwise. Any idea what the problem could be?
The projector was in security mode B which lock all of the projectors controls. I found the solution to this problem in an online manual for the projector. The solution is this button sequence: power-- enter-- power--enter-- power--- enter-- menu. This sequence unlocks the projector controls by resetting the security password.
Dec 17, 2009 | Sharp Notevision PG-M20X Multimedia...
Projector shuts off within 30 seconds of power on
is the led lit on the top of the projector? what colors?
green is ok.
red flashing in sequence:
2 times- lamp hours exceed 200 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fans not working. remove obstruction or replace fan.
5 times- temp too high. clean thoroughly.
solid red- undiagnosed error by projector. possible power supply or ballast.
also make sure the lamp door switch is working.
Aug 07, 2009 | InFocus LP 820 Multimedia Projector
Projector powers down and re starts over and over
the colorwheel, the ballast, or the power supply are not working properly.
Apr 16, 2009 | Eiki LC-XB20 Projector Multimedia...
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
LCD shutting off automatically
Hi there
Check if your blowerfan that cools the lamp - sits in front of Projector is running.
Nov 06, 2007 | BenQ PB2140 Multimedia Projector
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Electrical Problem? Projector works, but buttons don't.
IT MUST HAVE THE CARD INSIDE THE PROJECTOR WHICH IS DETACHABLE LIKE MEMORY/PCMCIA OR ANY OTHER. CHECK USB ALSO.
May 23, 2007 | Sharp Notevision PG-C30XU Multimedia...
NEC LT 260 Multimedia Projector Logo
155 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
