Question about Maytag Neptune MDG9700A Gas Dryer
Dryer will not heat or rotate
U select the program to dry & push start & everything appears to be working except the drum will not start to rotate & the heat doesn't appear to go on! This just started without any warning. Please help.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 05, 2010
Ignitor does not glow.
Normally a dryer will come on and then go out due to insufficient air flow. I your case, you say the igniter never comes on. This tells me that the thermistor is probably OPEN. With a cold dryer, the thermistor should close the contact and allow the relay to pull in. If you have poor air flow, the thermistor will heat and then break the circuit and stop the igniter from working.
Sep 07, 2014 | Frigidaire GLGQ2152ES Gas Gallery Dryer...
Dryer not running, just getting a click.
check you drum belt. if belt is broken nothing will come on.
Feb 25, 2014 | Amana NED7200TW Electric Dryer
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
The dryer drum does not rotate at all. The dryer itself will "click" on when I push the start button and you can hear the dryer and feel the heat but the drum won't move. We took the entire...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Dryers
Heatman - you comments are always dead on. You've help me extend the life of my dry twice. My current problem is this: When starting the dryer, the drum will not rotate, and the motor makes an...
it could be the extra weight on the motor and the motor is bad,try this,open the door,push the door switch in with one hand and spin the drum with the other hand and have someone push the start button,if it runs and most of the time it does because you're helping it along you need a new motor.one more thing,if the filter is in front,remove the duct that the lint filter slides into and spin the drum,if the blower wheel moves with the drum you have a bad motor,if it doesn't you have something stuck in the blower wheel and it jams up the motor because it's attached to the motor shaft.
Jun 10, 2011 | Dryers
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Maytag Neptune MDG9700A Gas Dryer Logo
79 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
