Question about Coleman Powermate Premium Plus 6250W Portable Generator
Can you tell me what oil to use in a coleman genpower 305 generator with a briggs & stratton 10HP motor?
3 Suggested Answers
philwalker78
  • 608 Answers
SOURCE: oil to used for a briggs and stratton genpower 305
Hi Jim, sae 30 mineral oil for all Briggs engines. Regards Phil.
Posted on Sep 26, 2011
  • 197 Answers
SOURCE: I'm looking for the 2 cycle oil to gas dilution
20:1 that's 1/4 pint to a full tank of fuel.
Posted on Jan 17, 2010
I have a Brigg and Stratton GenPower 10.0 portable generator. i noticed an oil leak and when i inspected the situation i found that there is gasoline where i fill the oil. Is this usual?
if what your saying is it seems like there might be gas mixed in with the oil that is not good but its not unusual for your oil to smell like gas a little
Oct 13, 2016 | Electrical Supplies
On a Generac model 1646-2 generator is the oil level switch normal open with full oil level.
I don\'t know, but change the switch or bypass it. They give plenty of problems & motor would start sometimes & not others.....Check the oil & rely on old style tech. I bypassed the switch on both of mine.after they gave problems & wouldn\'t run when needed....I only got a second one when I needed power & the switch was the only thing wrong ( I found this out too late.) & ended up with 2....
Jun 19, 2014 | Coleman Powermate Subaru 5000W Portable...
I have a briggs & stratton genpower 305. I pull chain to start and it does nothing. The chain feels like its loose.
Sounds like you don't have compression! It could be many things a broken piston, one of the rocker arms could be loose, or you actually have a broken rocker arm.Dissassemble where the rocker arms are and check if everything is in working order if it is take off the spark plug and check if you can see the piston going up and down . Let me know how it goes so we can try and solve the problem!
Jun 11, 2014 | Briggs & Stratton Power Products 5,550...
Looking for a carb for a Coleman Powermate 500/6250 generator with a 10hp Briggs and Sratton engine...any suggestions?
As it is a Briggs Engine most quality Briggs dealers can get the carb. It isn't special to Coleman I don't believe.
Oct 08, 2013 | Coleman Powermate Premium Plus 6250W...
Oil to used for a briggs and stratton genpower 305 10hp ohv engine
Sep 24, 2011 | Coleman Powermate Powermate 5000W...
Briggs and Stratton GenPower 11 generator cover plate ???
I have a Briggs & Stratton GENPOWER 11 generator that is electric start. The electric start will not start the motor or ever turn it over. I can turn the key on and jump across the terminals on the starter and it will run only if I continue to squirt starter fluid in the carb. My question is, if the ignition switch is bad, could that be the reason it will not stay running. My only guess is if the ignition switch is bad, the motor thinks it is in the off position at all times. Thanks, R Ray
Jul 16, 2010 | Coleman Powermate Premium Plus 6250W...
Where is the oil drain plug for a briggs and stratton 11 hp engine?
ACCORDING TO POWERMATE, THIS GENERATOR IS EQUIPPED WITH A 10HP SUBARU ENGINE. WHAT MODEL IS YOURS? AND R U SURE IT'S A B&G ENGINE?
Dec 14, 2009 | Coleman Powermate Powermate 5000W...
Oil capacity and weight of oil
If it comes with a Briggs & Stratton 3.5 HP series 93400 engine, then the oil capacity is 20 fl oz (0.59 L). Hope this helps!
Sep 20, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
317 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
