Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Just stoped now cant get it going.and ive cut the ht lead to short to fit to spark plug,because i thoyght it was spark but now think its fuel.
  • 518 Answers
Well might be fuel filter blocked,tap filter block ,,fuel may be dirty,seddiment,water,
Posted on Jul 05, 2010
Were do the ht leads go on fiat 1 2mpi
Technical: HT Leads diagram? - The FIAT Forum
www.fiatforum.com > FIAT Cars > Cinquecento / Seicento
Aug 30, 2008 - 9 posts - ‎3 authors Anyone got a simple diagram of where each lead goes from each plug to which ... Makesure the HT leads are on correct, then try them either way. ... As long as 1+4 spark plugs go to one coil pack, then 2+3 go to the other coil ... Fuel light flashing but won't start (No spark)
Nov 2, 2013
Fiat Punto 2001 8 valve 1.2 firing order
Feb 8, 2009
More results from www.fiatforum.com
ignition - Methods of diagnosing a non-starting Fiat Uno ...
Dec 01, 2015 | Fiat Cars & Trucks
Flat miss on cyl #6 on 3liter V6. It has spark and it has compression
Check the distributor rotor and the contacts on distributor cap, check that spark plugs are not dirty with oil, even if they are new.
If distribution is electronic take it to garage for scanner test.
Jul 24, 2008 | Toyota Pickup Cars & Trucks
What is the order of spark plug cables to the distributor for mazda 323 2001
On the distributor cap on each HT Lead connection there is a number presenting the spark plug connection with the cap. if the distributor cap has only the number "1" and not on the other hole for the HT lead connection then you fit the spark plug one lead and following the clockwise rotation fit the other HT leads. 1 for first spark plug,2-for second spark plug etc. First spark plug is fro the front of timing belt side. Good Luck!
Jul 03, 2014 | 1988 Mazda 323 Hatchback
Car wont start but kicks over
Since you do have A fully charged battery and also you do receive fuel smell after crank start and the car wont start,either you do have an Ignition fault means not giving the spark,advice remove the spark plugs and check whether are wet with fuel,see whether are black,if so change them and before start check by leaving an HT lead off a spark and use one of the old ones connected to the HT lead and earthed to the engine,ask somebody to start the engine checking for any spark comes out. If yes then put the HT lead back to the new spark on the engine and try. If ther is not any spark,then you have to go backwards from the HT leads to distributor,Rotor Arm,Electronic igniter,Coil if is fitted,Fuse and relay. Good Luck.
May 28, 2013 | 1995 Jeep Grand Cherokee
My mazda 626 will crank over but will not start i think someone took a fuse out
check if the car is firing by pulling an ht lead off the plugs and put another spark plug on the ht and earth the spark plug if it has spark when cranking if it is there check the fuel system if the fuel is getting to the injectors.
Jan 23, 2013 | 1998 Mazda 626
Mantis-20 will not start - have tried new fuel?
Hi, chances are the old fuel has gone bad and caused the spark plug to get muck on it, i would go out and buy a new spark plug then leave the plug out but fitted to the ht lead, then rest the plug on a metal part of the engine then try stating it and make sure you have a good strong spark between the gap in the plug, if you have a good spark then take the plug out the ht lead but also leave it out the engine, then keep pulling the starter for about 20 to 30 seconds to ensure you have only the new fuel coming through into the combustion chamber, you should be able to smell the fuel after few seconds, then put the spark plug back in and try starting it, you should find it will now start.
let me know how you get on or if you need further assistance ok
Mar 07, 2011 | Mantis 2-Cycle Tiller
REWIRE SPARK CABLES 95 CHEVY CORSICA V6
Hi, I am not aware of your skills level, however, some office "WHITE OUT" or white paint etc will vastly assist you to complete the task successfully. Pick a lead in the cap, mark it's location with a dab of white out / white paint, follow the wire, (HT lead) to it's spark plug, very carefully remove the spark plug connection and / or rubber boot if fitted. fit the replacement lead and route it back to the cap. Carefully remove the original cable and fit the replacement. Do the same for the rest of the cables,(HT leads) marking the cap as you go, ie, a,b,c,d or a number sequence your choice.. Remember, doNOT remove all cables at the same time. Change out one at a time, and you will not mix up the firing order.
It is a wise precaution to replace the cap and rotor,when you replace the cables, (HT leads.). .
Good luck.
Feb 01, 2011 | 1995 Chevrolet Corsica
Engine has no spark. 3HP Briggs and Stratton +
If you get a shock from the HT lead then you do have spark!!
Connect spark plug with it removed and shorted to see if there is spark, if not use screw driver to hold away from steel (1/4") with end inserted in HT lead,If good spark / faulty spark plug.
Check for
Spark
Fuel to spark plug
No air leaks.
Mar 16, 2010 | Briggs & Stratton 1928 1 amp Transfer...
Hard starting when cold cuts out
its an old car have you checked the the ht leads do it in the dark to see if there are any sparks or arcingit could just dampness cut the tips out of a rubber glove thread the leads through the wrist part will fit over the distrubuter that should keep the damp out outherwise change all ht leads
Nov 11, 2009 | 1989 Toyota Camry
I can only find three spark plugs on my freelander v6 engin
Remove
  1. Disconnect battery earth lead.
  2. Remove engine acoustic cover.
  1. RH bank only: Release locking clips and disconnect multiplugs from plug top coils.
  2. RH bank only: Remove 6 bolts securing plug top coils to RH camshaft cover and remove coils.
  1. LH bank only: Noting their fitted positions, disconnect ht leads.
  2. Using a 16 mm plug socket, remove spark plugs from both cylinder heads.
Refit
  1. Set gap of each new spark plug to 1.00 mm .
  2. Fit spark plugs and tighten to 25 Nm (18 lbf.ft) .
  3. LH bank only: Connect ht leads.
  4. RH bank only: Fit plug top coils to spark plugs.
  5. RH bank only: Fit bolts securing plug top coils to RH camshaft cover and tighten to 9 Nm (6.5 lbf.ft) .
  6. RH bank only: Connect multiplugs to plug top coils and secure with locking clips.
  7. Fit engine acoustic cover.
  8. Connect battery earth lead.
Jun 04, 2009 | 2003 Land Rover Freelander
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
43 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
