Question about Husqvarna EZ4824 24 hp 48" Zero Turn Lawn Mower
I have a husqvarna ez4824 zero turn lawn mower. When cutting grass it keeps disengaging. Any idea why?
  • 755 Answers
Either a weak seat switch or your electric clutch is going bad!
Posted on Jul 06, 2010
Testimonial: "Thank you very much for your input. You were right - it was the clutch."
23hp vanguard briggs & stratton repair manual
I Googled this in 15 seconds. Here's the manual in PDF:
http://www.husqvarna.com/ddoc/husi/husi2007_usen/husi2007_usen__539131361.pdf
Jun 12, 2016 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
It start when put in gear it cut off
it sounds like you may have a switch that has come UN plugged, dirty connection or just a bad switch. check all of the switches. seat blade and brake. you can check these with a continuity tester. you tube has many videos on how to check. i hope this solves your problem.
Mar 19, 2016 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
Husqvarna EZ5424 lawn mower zero turn mower deck will not engage checked fuse checks good where is the electromagnetic coupling located and what is its purpouse?
The electromagnetic coupling is on the bottom of the crankshaft under the mower engine. When the magnets are engaged (power is supplied), they activate the pulley that moves the deck belt.
Jun 22, 2014 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
When do you know when the clutch is shot? My problem is it doesn't want to mow thick grass and seems like maybe the belt is stretched.
It does sound like a belt problem, if possible replace it with a kevlar belt, they last way longer and will survive more abuse.
Jun 20, 2014 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
Electrical problem?
I had the same problem with my exmark. I found that there was a yellow wire that has a deans connector that plugs in around the backside area of the key ignition. that wire vibrated off. check that, it may fix it. good luck!..
Dec 07, 2013 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
Leaves uneven grass behind mower
Do you mean it is cutting the grass lower on one side. If that is what its doing there is several things that will need to be checked starting with the blades first. Remove the blades and inspect, making sure you have not maybe bent one. If blades are OK, Next I would check and make sure the blades are installed or seated properly. Some have a spacer, if yours have spacers make sure they are on both sides While doing this you can also check the spindles for play in the bearings. They should turn freely with no up/down play. If this doesn't help there are other things it could be however this is my best guess. 30+yrs working on mowers.
Sep 29, 2013 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
When I engage the blades on my ez4824 the blades intermittently stop cutting particularly in higher grass. Do you think this is a loose belt problem? Thanks.
That is the most likely cause of the problem - taller and thicker grass the blades encounter more resitance and the drive belt slips and it doesn't cut. This would likely cause a juddering of the machine when it occurs.
Hope this helps.
Jul 11, 2011 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
Husqvarna EZ4824 24 hp 48" Zero Turn Lawn Mower Logo
555 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
