? 5:13 www.youtube.com/watch?v=tgfRmBo7Pu0 Nov 13, 2009 - Uploaded by Factory Car Stereo Repair
Acura and Honda Radio COdE Retrieval and Unlock Tips .... mine is Honda Accord 93, click what button to active it? .... Radioreset code in 5 minutes for a 2001+ Honda CRV CR-V Accord Civic Pilot Element Odyssey Insight ...
when battery dies the radio deems this to be that someone is trying to steal it and it goes into anti-theft mode and disables itself u need to notify a dealer the codes are dealer issued because they are considered a part of the vehicles security system call the dealer first will explain how to retrieve the radio id number which is needed
Opposed to a blown fuse, most likely the drained/dead battery caused the radio to "reset" itself. You should have a 5 digit (or 4) code that was provided by the dealer or owner. Most owners write it down somewhere on their owners manual. If not, the dealer can give you the code. Once the code is entered, you back in business!
try taking the radio out and looking on the top for the parts number. call Honda and tell them what is going on and they will give you a 4 digit code that will reset the radio. i had the same problem with my 05 civic, did that and it worked for me. good luck
TRY DISCONNECTING THE BATTERY TERMINALS FOR 5 MINUTES. BE AWARE THAT THE STEREO MAY HAVE A LOCK OUT CODE. RETRIEVE THIS CODE BEFORE YOU DISCONNECT THE BATTERY. HOPE THIS HELPS. BEST OF LUCK TO YOU.
DOES SYSTEM INTAKE CODE YOU TYPE AND RETURN WITH ERROR MESSAGE OR JUST PLAIN HAS LOCKED SCREEN? SYSTEM IS DESIGNED SO THAT IF INCORRECT CODE IS INPUT MORE THAN THREE TIMES SYTEM LOCKS ITSELF.WHICH REQUIRES THAN THE NAVI UNIT BE UNPLUGGED FROM BATTERY POWER FOR ABOUT 5-10 MINS TO RESET ITSELF.NOW INCORRECT CODE CAN BE DUE TO WRONG CODE/SERIAL # CARD FOR VEHICLE, UNIT HAS BEEN REPLACED IN PAST POSSIBLY AND YOU ARE INPUTING CODE FROM OLD UNIT UNKNOWINGLY. YOU ALSO WANT TO MAKE SURE CODE YOU ARE TRYING TO INPUT IS FOR NAVI-SYSTEM AND NOT THE RADIO CODE FOR THE STEREO. IF ALL ABOVE CHECKS OK THEN NEXT STEP WOULD BE TO REMOVE UNIT TO RETRIEVE SERIAL NUMBER FROM BACK OF NAVI UNIT THEN GO TO NEAREST DEALARSHIP WHO CAN THAN RUN S/N THROUGH HONDA IN SYSTEM AND RETRIEVE CORRECT CODE FOR THAN SERIAL NUMBER. LET ME KNOW HOW IT GO'S
I won a 2004 Honda Civic.
I had a bad battery and my car would not start. I had someone jump start it and it now has a new battery. The car runs fine but the stereo will not play am/fm or CD's. Regardless of what I do I get an "Error E code"
