Hotpoint wdd960 error code F005 lock symbol showing but can open door and it's full of water. Can't pump out
gittos73
  • 244 Answers
SOURCE: Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Posted on Aug 23, 2007
  • 118 Answers
SOURCE: Fabric Softner Tray
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Posted on Sep 02, 2009
beltronic205
  • 1474 Answers
SOURCE: door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Posted on Nov 02, 2009
  • 29 Answers
SOURCE: hotpoint wdd960 washer dryer error f05
f05 means blockage and cannot drain-switch off at mains to reset error-turn to drain if pump runs but dont drain filter in sump blocked/if no pump action then somthing is jammed inn pump
Posted on Nov 10, 2009
  • 51 Answers
SOURCE: how do i get to the pump on the hotpoint wdd960
REMOVE PLUG from the wall socket. at the rear of the machine you will see a small panel at the bottom, remove the 3 screws holding it in place and have someone hold the front of the machine tilted forewards. you will see the sumphose that collects foreign objects that have entered the machine, if this is full it will not empty effiecently or not at all. the pump its self is next to this sump.
Posted on Feb 02, 2010
Hotpoint aqualtis aqxxf149hpi is showing a error h20
Check tube to water pressure switch. The wall of the rubber tube on my machine had worn through due to friction. Taped it up to make sure this was the problem. No H2O code and machine working!
May 27, 2014 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wdd960
This is usually because there is water in pump which does not get drained over time. Leave the porthole door open from time to time to let the odour out. Make sure the laundry drain backflow has not dried up causing sewer smell to come through.
Run the washing machine empty using a packet of cleaning agent available from supermarket. see this site
http://www.hillmark.com.au/products/scalexplus.aspx
Apr 22, 2014 | Washing Machines
Wdd960 f13 error code
you could have a problem with the fill valve,shut the water supply off,remove the hoses from the back of washer and mark them so you put them back the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses you'll know it's the washer and not the house water valve.if water comes out look into the washer valve where the hoses connect,if you see alot of junk on the screens change the water valve.i want to tell you that i haven't worked on this machine yet,i looked up your error code and it sounds like you're having water issues from what i've read,there's a tech sheet in the washer sometimes down near the bottom cover or taped onto the side wall,it will have all the error codes and tell you how to run the machine in a diagnostics mode to check everything in it,also next time you write in send the full model number off of the machine you're having problems with so whoever is trying to help you can look up your machine,usually you open the door and look around the opening where the door closes in and you should see a tag with the model and serial numbers.hope this helps,best thing to do is find the tech sheet and run it in diagnostics
Jun 23, 2013 | Washing Machines
Hotpoint WDD960 Washer Dryer - no error code but whenever I put it on a dry cycle it just spins as if working but without actually drying. Any suggestions?
Sounds like heating element is not coming on ..Heating first then with a Fan motor running and water flow the steam that is produced by the heaters are changed to water by the cold water over a condenser , the pump then puts his out to waste..
Jan 28, 2011 | Hotpoint Washing Machines
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hi, my ultima machine door wont open and says error code f-05, can you help.
Link to the service website: http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
From the owner's manual under troubleshooting:
Error code: F05 - Pressure switch jammed on full
The door will not open...
● Has the programme finished? Is ‘End’ lit
in the display window and the ‘Keyhole
symbol deactivated?
The door will not open until the ‘Keyhole
symbol goes out shortly after the
programme has finished.
● There is still water in the machine.
Go through all the points in the next
section,‘The machine will not pump out
water...’
The machine will not pump out the
water...
● Make sure that there is no blockage in
the drain hose and that it is not kinked.
● Is the drain hose installed correctly?
● If you have connected your machine to a
sink waste system, make sure that you
have cut out the membrane from the
under sink drainage system.
(see section: INSTALLING YOUR
MACHINE).
● Ensure that the drainage system,
standpipe or under sink connection is
free from any blockage.
- If any of the above are found to be
the cause of your problem you will need
to run the machine through a spin only
programme.
● If you have chosen ‘Rinse Hold’, the light
will flash until you press the ‘Rinse Hold’
button to continue the programme.
Jan 16, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint wdd960 washer dryer error f05
Nov 08, 2009 | Washing Machines
Door lock symbol showing on screen and door will
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
169 people viewed this question
Top Washing Machines Experts
