Question about Coby 2.4GHZ SILVER Phone (CTP7000SVR)
What is an out of range indicator - Coby 2.4GHZ SILVER Phone (CTP7000SVR)
  • 8,404 Answers
Out of range means your hand set cannot communicate with its base set. Several possibilities ... one ... you are simply too far away (more than 100 <> feet) ... two ... you have battery issues ... three ... you have metal based wall paper on the walls of your home. There are other reasons ... these are the ones I have had experience with.
Thanks for your interest in FixYa.com ... please evaluate this response.
Thanks.
Posted on Jul 05, 2010
I am trying to determine when my gas range was manufactured - 362-7585590 is the model number. And who manufactured it. Thank you.
The 362 code indicates that the range was made by GE. The manual for the range is available here: http://www.searspartsdirect.com/partsdirect/user-manuals/3627585590-kenmore-parts-gas+range-manual?manualIndex=0 . To download the manual go to http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0801065.pdf . You need the serial number of the range to determine the date of manufacture.
These sites may help: http://products.geappliances.com/appliance/gea-support-search-content?contentId=16195 and http://www.appliance411.com/service/date-code.php . The first site lists how GE adds the date code in the serial number. The second site will give you the manufacture date after you fill in all of the details.
I hope this helps.
(Some code lists indicate that the 362 prefix indicates a Roper appliance built with GE parts.)
Apr 07, 2017 | Kitchen Ranges
Where is the neutral safety switch on a2004 chevy Malibu, 3.5 L engine
The transmission range (TR) switch is part of the park/neutral position (PNP) and back-up lamp switch assembly (1), which is externally mounted on the transmission manual shaft. The TR switch contains four internal switches that indicate the transmission gear range selector lever position. The PCM supplies ignition voltage to each switch circuit. By grounding one or more of the switch circuits, the PCM detects the selected gear range by the state change of the switch input. Refer to Transmission Range Switch Logic . Switch input to the PCM is represented on the scan tool as HI and LOW. HI indicates an ignition voltage signal. LOW indicates a zero voltage signal. The four parameters represent transmission range switch signal A,B,C and Parity.
Look on transmission where the shifter cable hooks up !
Dec 06, 2016 | 2004 Chevrolet Malibu
The preheat indicator stays on my electric oven? What could be the problem?
I appreciate your inquiry, Sidney!
I see that you are having a difficulty with the preheat indicator on your Frigidaire range constantly staying on. This could be a possible issue with that switch or indicator light. I would recommend seeking help from a certified technician for exchanging or replacing any electrical components. This will prevent any personal injury or future issues with your range. I hope this is helpful information. -Matt
Aug 13, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
Plymouth grand voyager 1999 is not showing the readings on my dash for the fuel, speedometer, and has not passed emissions. What could be the problem?
Here is the procedure to check the gage connector on the back of the instrument cluster. The procedure is a lot longer if you have a mechanical PRNDL indicator in the cluster. I'm thinking you don't. You don't need to remove the cluster as the procedure says, because you're just going to check the connectors on the back. You just need to take the screws out and tilt it forward far enough to reach in and push the connectors in.
REMOVAL & INSTALLATION See Figures 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 and 12
Fig. Fig. 1: To access the instrument cluster mounting screws, remove the lower bezel ...
Fig. Fig. 2: ... and the driver's side end cap ...
Fig. Fig. 3: ... to access the upper trim bezel screws. After removing all of the screws ...
Fig. Fig. 4: ... carefully pull the upper bezel from the instrument panel
  1. Disconnect the negative battery cable.
CAUTION The models covered by this guide are equipped with a Supplemental Restraint System (SRS), which utilizes a driver and passenger side air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described earlier in this section.
Fig. Fig. 5: Once the bezel is removed, the instrument cluster mounting screws can be removed (two on each side)
  1. Disable the air bag system.
  2. If equipped with a mechanical transmission range indicator, perform the following;
    1. Remove the lower steering column cover.
    2. Remove the knee blocker reinforcement panel from under the steering column.
Remove the indicator cable loop.
    1. Remove the clip securing the gear shift cable end to the gear selector adapter.
    2. Pull the cable end from the gear selector.
  1. Remove the instrument cluster bezel.
  2. Remove the mounting screws securing the instrument cluster to the instrument panel.
  3. Rotate the top of the cluster outward.
  4. Disengage the wiring harness connectors from behind the cluster assembly.
  5. Remove the instrument cluster from the vehicle. If equipped with a mechanical transmission range indicator, carefully guide the range indicator cable and guide tube through the opening to avoid any possible damage.
Fig. Fig. 6: After the mounting serews are removed, reach behind the cluster and unplug the electrical connectors ...
Fig. Fig. 8: Instrument cluster mounting detail (models with a mechanical transmission range indicator)
Fig. Fig. 9: Range indicator cable mounting detail
To install:
  1. If equipped with a mechanical transmission range indicator, verify the free travel of the range indicator cable from P to 1 by gently pulling on the cable, then relaxing the cable. Do NOT snap the cable once it is pulled.
  2. Position the instrument cluster assembly into the instrument panel by leading the bottom of the cluster in first, plug in the wiring harness connector(s), and rotate upward. If equipped with a mechanical transmission range indicator, route the indicator cable and guide tube through the opening in the instrument panel.
Fig. Fig. 10: On models with a mechanical transmission range indicator, the cable must be accessed by removing the lower steering column cover. Remove the mounting fasteners, and lower the cover ...
Fig. Fig. 11: ... disconnect the parking brake cable ...
Fig. Fig. 12: and remove the reinforcement
  1. Install and tighten the instrument cluster mounting screws.
  2. Install the instrument cluster bezel.
  3. If equipped with a mechanical transmission range indicator, install the indicator cable and guide tube. Install the cable retaining clips.
  4. Install the knee blocker reinforcement panel.
  5. Install the lower steering column cover.
  6. Connect the negative battery cable.
Apr 01, 2011 | Plymouth Voyager Cars & Trucks
On indicator lamp stays on even after all knobs have been turned off
One of your burner switches is defective.
it should be replaced,however,it is not dangerous.
Jul 12, 2010 | Maytag MER6772 Gemini Electric Kitchen...
The cooktop indicator light is still on even when all the knobs are in the Off position on my Whirlpool range model RF265LXTY
MOST SMOOTH TOP ELECTRIC STOVES THE INDICATOR LIGHT WILL STAY ON UNTIL THE BURNER COOLS OFF.IF THE BURNER IS COOLED THEN ONE OF YOUR SURFACE BURNER SWITCHES IS BAD AND WILL NEED REPLACEMENT .HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Dec 12, 2009 | Whirlpool RF265LXT Range
Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Oct 09, 2009 | Kitchen Ranges
'04 Trailblazer. Indicator shows drive but it's not in drive.
The transmission range (TR) switch is part of the park/neutral position (PNP) and backup lamp switch assembly, which is externally mounted on the transmission manual shaft. The TR switch contains four internal switches that indicate the transmission gear range selector lever position. The powertrain control module (PCM) supplies ignition voltage to each switch circuit. As the gear range selector lever is moved, the state of each switch may change, causing the circuit to open or close. An open circuit or switch indicates a high voltage signal. A closed circuit or switch indicates a low voltage signal. The PCM detects the selected gear range by deciphering the combination of the voltage signals. One of these circuits it what is causing your problem but I hope this helps you understand some.
Jul 06, 2009 | 2004 Chevrolet TrailBlazer
Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
May 30, 2009 | Kitchen Ranges
Coby 2.4GHZ SILVER Phone (CTP7000SVR) Logo
79 people viewed this question
Top Coby Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Coby Lands Phone Expert? Answer questions, earn points and help others
