Question about Dell Inspiron 1525 Notebook
Networking with xp n windows7 system
I'm using windows7 system n i want to connect a xp system using lan cable..... but i'm not able to access the data from both the systems..... in both the systems i hav installed lan drivers..... can anybody help me how to access the data.......
  • chandu_043 Jul 06, 2010
    ya sure sir i'm using the crossover cable only but still got the prblm any other solution is there?
  • 3,940 Answers
If you are connecting directly from computer to computer, you need a crossover cable (Cable specific to direct computer to computer connection) otherwise you need two cables and a hub/switch/router to connect.
Posted on Jul 05, 2010
Nvidia nforce network controller
google translated
engo deshabilitadad wireless network and can not find the drivers windows7 teengo is a acer aspire 4520
Your Acer computer has a networking card installed so that it can connect to a wireless local area network (LAN) to share files or surf the Web.
By using a wireless network, you can bypass the need to run cables between different rooms in your office or home.
To set up a wireless LAN, you will need to change settings in the computer's operating system and use the eNet Management software that Acer provided.
Connect an Ethernet cable to the "Wide Area Network" port on the back end of your wireless router.
Attach the other end of the cable to the Ethernet port on the back end of your high-speed modem.
nsert the installation disc that came with the wireless router into your Acer computer's disc drive.
Follow the on-screen installation instructions.
Access the Acer's Start menu and open the Control Panel.
Click "Network and Sharing Center," and then choose the "Set up a new connection or network" link.
Choose "Set up a new network" and then "Next."
Enter a name for your local area network, such as "Home" or "My Network," into the "Network Name" text field.
Type a password for your network in the "Security Key" text box and click "Next."
Click "Finish." Right-click the "Acer eNet Management" icon in the Windows task bar.
Scroll to "Available WLANs" and then click the name of the network that you chose earlier.
Type in the password you chose earlier and click "OK" to connect your Acer to the Wireless LAN.
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Jul 19, 2013 | Acer Aspire Computers & Internet
Tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
Can access lan internet
lan stands for local area network so if your connected to the internet your already accessing lan network.
Sep 30, 2012 | Microsoft Windows XP Home Edition
Hi. I have a Vigor 2910g router. The router is working. Im trying to change the configuration, but i cant access the web page. Im connected directly to one lan port. I type the router IP in the web browser...
These are the general steps to all wireless connectivity.
Click the link below for proper cable connections in setting up your wireless network.
This link also provides somewhat a checklist on what you need for wireless connectivity.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Jan 31, 2011 | Draytek Vigor 2910G Dual WAN secure...
I have installed win xp, its unable to detect LAN connection, no icon dispays for internet, Lan cable light is coming
using another computer with internet access , you must go to the system website and support drivers tab. select your system via info requested and then download the network driver listed in the search. save this to a flash drive , or cd media and then run the application in your computer. this will allow your ethernet to function properly. this is a very typical problem when doing a fresh install with windows xp. if your display adapter settings are not correct. the problem can be solved following the same procedures and selecting the video driver for your download.
Jan 19, 2011 | Computers & Internet
I am installing with my Sony VPCZ1 PC but cannot get past the first task which says my wireless adapter is still turned on when in fact it is turned off? I am running Windows7. Can you please help?
First;I think you need to use W7 to configure your connection with the router.
But try :
Use the PING command to test the communication between the computer and the gateway.
Goto Start > Run and enter COMMAND.
From the Command Prompt, enter PING 192.168.0.1.
The gateway should reply.
Verify that the residential gateway is getting power. With the broadband modem connected to the WAN port on the gateway, you should have a soild WAN link light. You should use the same cable that connected the modem to the PC to connect the modem to the WAN port on the gateway. Any port on the gateway that has a computer connected to it should have the corresponding LAN link light lit. If you do not get the appropriate link lights, try using different cables.
Minimum System Requirements• Cable or DSL Modem
• Computer with:
• Windows® Vista*, Windows® XP SP2*, or Windows® 2000 SP4*, or Mac OS® X (v10.4)**
• Internet Explorer v6 or Mozilla Firefox v1.5
• CD-ROM Drive
• Network Interface Card
• For Internet Access:
• Subscription with an Internet Service Provider (ISP)
Nov 11, 2010 | D-Link DIR-615 Wireless Router
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
I have forgotten my password for my wireless internet connection.
Connect to Wireless router using LAN cable.
Open Router admin page using the gateway address you get from your network status window from Systray (Support tab in XP).
Follow router instruction to set new WLAN protocol and Password (WPA-PSK for better protection) and use new passphrase (or Key) to set PC client network card protocol.
If Router is Password protected and you missed it: reset to factory settings to reconfigure.
Dec 27, 2008 | Intel PRO/Wireless 2011B LAN Enterprise...
Sir i we are 2 friend connected with LAN hub we want to connect via LAN. i want LAN setup between us
yes for this you both have to set workgroup name same .first connect the LAN cable to lan ports of yours...then in Network setting give manual ip addreess as 192.168.1.1 in one computer and in other as 192.168.1.2 (subnet mask would be same) .then u bath can access each other computer by sharing folder....
but you have to disbale windows firewalll
Dec 09, 2008 | Microsoft Windows XP Professional With...
Sony PCG-4g1m
Plug in the LAN cable (CAT 5) into your laptop network jack. Make sure the other side is plug into the network outlet jack. Now confirm that you have a link on your LAN adapter, if your laptop has lights for the LAN adapter built in. If it doesn't don't worry. If its connected windows xp will say if its connected or not. If its connected it will try to find a IP address. Make sure DHCP is enabled (Should be set as DHCP as default anyways) if your laptop doesn't get and IP address then there's something wrong with the network your connected to and not your laptop. Contact the system administrator (IT guys) in charged of that network.
**** IF AND ONLY IF***
IF there's no network icon in the taskbar tray then your network adapter is disabled. To enable this right click the network icon on your desktop and select properties now a windows opens up and right click on your LAN adapter and select enable... let windows do its magic and you should be back to normal.
GOOD LUCK!
Aug 19, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
