Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
GSS22JEMD BB G.E. SIDE BY SIDE FRIDGE
HOW DO I CHECK FOR 12 V @ EVAPORATOR MOTOR
  • moneyclip Apr 19, 2008
    got a volt meter need to know what lead go where.
  • 828 Answers
Nothing to my knowledge in a side by side refrigerator freezer works on 12 Volts. Evaporator fan motors are generally 115 Volts.
Posted on May 15, 2008
    Genius:
  • 1,073 Answers
Use a volt meter that reads dc voltage
Posted on Apr 18, 2008
JCD2289AES jennair fridge refridgerator side is not cold but the freezerside works
The fridge side is not getting enough cold air from the freezer side. This could be due to a few things. The vents from the freezer is blocked, or the evaporator fan/motor has failed, or the evaporator coil is iced up due to the defrost circuit failure.
To check which is the problem you will need to empty the freezer to you can get access to the panel that covers evaporator coil. After removing the panel check to see if the fan is turning, also note whether the evaporator coil is iced up. If it is iced up, then the defrost circuit is failed. The problems usually are a failed defrost heater, defrost timer or defrost thermostat.
Aug 12, 2010 | Jenn-Air Refrigerators
Fridge warm, Freezer OK
You will find very good info HERE.
Good Luck.
Mar 03, 2008 | Samsung RS2578BB Side by Side Refrigerator
Freezer is working fine, but Refrigerator is not cooling?
Little more complex than that. You will have an evaporator fan motor and and possibly an Auger motor depending on the sophistication of your fridge. If these items are frozen up, it will create the scenario you are experiencing with your fridge. Suggest a 12 hour defrost period to totally remove ice. Clean up excess water and retry.
May 27, 2010 | GE GSS25SGMBS Side by Side Refrigerator
MY REFRIGERATOR MODEL#GSS20IETA BB DOES NOT GET COLD IN THE REFRIGEATOR SIDE . WHAT COULD THIS BE?
open the freezer and listen for the evaporator fan motor, if you can't hear it running then you need to replace it. it pushes the cold air from the freezer into the fridge to keep it cold.
Nov 13, 2009 | GE Refrigerators
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice build-up in lower freezer. We replaces the
warm between doors is normal. if hot then clean coils and if coils clean make sure condenser fan motor working thats the fan in the back compartment, however if warm thats good. did the evaporator coil freeze from top to btm is that why u replaced heater. if it was then could be heater,if the coil is only getting frost on half the coil,you could have a sealed system problem. is the evaporator motor working in the frz side if not,then that could be the problem.if coil is froze up it needs to be defrosted. did you defrost coil when you replaced heater,if not try defrosting coils and then wait about 12 hrs and see how it does.
Sep 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
My fridge freezer made by samsung is on the blink
These fridges have an evaporator fan motor on both sides - the freezer and fridge side. The freezer can maintain it's temperature because that fan is working fine. I had the same problem, and replaced the evaporator fan motor on fridge side, and it solved the problem. Also, if your fan motor is not working well, or stops working, the evaporator is prone to ice build up, and will prevent proper cooling. You may want to open up panel on fridge side and see if that's the case. Taking a blow dryer to the evaporator and surrounding area (while fridge is off), or letting it sit for a few hours might solve the problem. Ultimately though, it appears as if these fan motors are prone to failure, and need to be replaced.
Dec 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Ge side by side model # GSS22JEMD BB
YES see if you have 12 volts dc at the evaperator motor if you do then the motor is bad if you do not then the mother board is bad and ge recomends in this case to also change the fan motor at the same time
Apr 17, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
Fridge not cooling
Check and see if your evaporator fan motor is working in the freezer. Also, if your defrost system is not working and your evaporator coil is frosted up, you will not get any cold air to the refrigerator section. You should see alot of frost on the back wall of the freezer where the evaporator coil is located. If your evaporator fan motor is working and there is no frost build up on the coil, the air diffuser to the refrigerator section may be the problem. Put your hand in front of it when the evaporator fan motor is running and feel if any air is coming thru. There are a number of conditions that can cause your problem. This should get you started! Visit me on Ebay as username: themackshack. Good luck! Mack
Mar 23, 2008 | Refrigerators
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Feb 07, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
342 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
