Computer to computer
I would like to transfer my stuff off of one haed drive/computer that isn't working properly.
the monitor is not comunicating with the hard drive.
how can i do that?
also, i have a belkin omni view 4 port ps/2. how do i use that or can i use it?
    Scholar:
  • 104 Answers
The easiest way to transfer your files is to attach your old drive to the new system as a 'Slave' drive. The system will assign a new drive letter to your old drive. Your files can be accessed and copied using Windows Explorer, not Internet Explorer. If you have a cd drive using the slave connector, connect the old drive with a new ribbon cable to the other IDE port. Set it to Master.
Posted on Apr 17, 2008
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
My computer is not communicating with the monitor,what could be the problem?
hello,
not comunicate meaning the cables are not properly connected this is the first step the second maybe you monitor is not working(unlikely) and the last option is that your video card is busted and does not give a signal to the monitor,try the above situations
Dec 05, 2012 | Dell Computers & Internet
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
TFT185W80PS monitor is not working
Check if your monitor power led indicator is on if it is, try to check the cables of your monitor if it is properly plugged to your CPU if it isn't plugged it properly if the problem still doesn't solve try to open your cpu and and uninstall your video card if you have a separate one and clean it with a pencil eraser then install it again and try it if it will work. But if your video card is built in, there is a problem with your video card or maybe your monitor try to contact a reliable computer technician..Hope it will help you.
Jul 02, 2011 | AOC widescreen 931SWL LCD TFT 19" Monitor
Transfering photos to my Iomega Prestige 500GB Portable Hard Driv
Does the Iomega show up under 'my computer'?
It should be another drive (D, E, F whatever) and as such you put stuff on to it the same way you would put stuff on to your C drive.
Mar 16, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
My problem is no sound Per the computer it shows it is working and I have tried everything to figure out what the problem could be.
Please cool down & smile (very important) ha ha...
Now, go to your control panel / sound or audio / audio tab / sound playback! Here you need to choose your proper default output device. ( the said path depends on the OS you are using)
Apply changes & exit. BINGO!
Please send us your votes & feedback!
Feb 21, 2010 | HP W2007 LCD Monitor
Acerw-1.scr
Acer w-1.scr è uno screen saver. Problema è che il risparmiatore dello schermo ha smesso di funzionare. Questo è un problema comune con Acer computer. Cerca questo file ed eliminarlo!
Jul 12, 2009 | Acer Aspire™ T180 PC Desktop
Computer not comunicating with monitor,modem,mouse & Kboard
Is the pc's motherboard getting past post , ie,do you hear a beep at all just after you switch it on,take the cover off , do you see any fans moving , any sign of life?,
Jun 18, 2009 | Gateway GM5664 Desktop PC
Pc question
with motorola phone tools
or bluetooth
Feb 22, 2008 | Motorola Mobility RAZR V3
Computers & Internet Logo
David Payne
David Payne
