Question about Fisher and Paykel Washing Machines
Hi. i have a gentle annie washing machine
The bowl keeps spinning when it agitates and shutting it down. any answers? cheers
SOURCE: gentle annie motor wiring
This according to googled results, and somewhat verified by me:
For the Gentle Annie connect the white/orange/green wires together to from a
star point and the three other ends (red, yellow & blue) go to your 3 phase
rectifier.
You can leave the others hanging. Don't form the star point with the wire
that's green with a yellow stripe, that's the chassis earth. The brown,
purple, and brown with black stripe I think are sensing coils, with a star
point connected to the black wire. 1.4ohm each, whereas the main coils are
4.8ohm and apparently rated for 5A.
Posted on Feb 01, 2009
  • 188 Answers
SOURCE: My washing machine spins but will not agitate
Turn the agitator (auger) by hand. It should work like a ratchet (turns one way, locks the other way). If it spins both ways, you need to replace the agitator dogs (funny name, I didn't make it up).
This can be done by removing the top cover off the agitator and removing the bolt that holds the agitator to the drive shaft. Then remove the top section, flip it over and replace the dogs (small white plastic pieces). Reassemble in reverse manner.
If the agitator dogs are ok, you may need a gearcase (transmission).
Posted on Feb 19, 2009
  • 126 Answers
SOURCE: My maytag washing machine spins but won't agitate.
sound like the agitator motor went out the way to fix this is to take the agitator out and replace it along with the motor
Posted on Sep 01, 2009
  • 59 Answers
SOURCE: I have a Fisher and Paykel ECS Gentle Annie GW52-k
Make sure there is voltage going to the valve solenoids. That is what opens up and lets water into the washer. You will have to open up the top of the washer control. The valve assembly is where the hoses screw in the back. I don't have the technical on it but most likely should be 120V. Sometimes the valve goes bad and won't open up.
Posted on Feb 17, 2010
  • 713 Answers
SOURCE: Fisher & Paykel Gentle Annie washing screeching sound
remove drive belt.check 2 see if main drive pulley turns freely.check to see if motor turns freely. could b belt. what country r u in . parts hard 2 get in australia. please reply 4 more help. please turn off power b4 u work on it. do not want any accidents.good luck
Posted on Apr 10, 2010
Hi, My Fisher & Paykel GW612 washing machine is not spinning, just thumping back & forward, error code 40 on the lights tells Me to carry out a clutch disassembly procedure any help please !!!
Inner spin bowl rises up when water level is high & disengages a clutch gear. When water drains out bowl settles back down and gear engages. Error 40 is saying that the gear has not locked in place and engaged. Remove lid, take out agitator. Under agitator is a cap held in place with 4 screws. Take out screws (do not drop them down through the slots in the bowl) Take off cap & gear underneath will slide up & off the shaft (gear will be tight to pull up due to soap build up.) Inspect gear for damage & clean out any dirt or obstruction. Re assemble and try wash cycle. If you still get the same fault you may have a faulty control board.
Jul 07, 2017 | Fisher and Paykel Washing Machines
Remove agitator gentle annie ECS
the is actuallt a special spanner for it which is now unavailable
Dec 19, 2012 | Fisher and Paykel Washing Machines
How do you remove the agitator from a gentle annie about ten years old
HI,
It takes special tools tyo remove the Agitator.
Sometimes the agitator is stuck to the spline and special tools have to remove it
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Washing Machines
I have a eziset 605 it will wash the clothes but when it comes to the spin cycle it wont spin but the agitator still turns causing the clothes to become tangled on one side causing to unbalance. i have...
If you look you will find that when the machine is supposed to spin that is the spin bowl turn. Instead of the spin bowl turning, the agitator is turning and so BALLING the clothes. So......it is most likely a *** designed machine so it has a brake arm and pawl, operated by a small motor or a solenoid. This motor or solenoid is most likely not pulling the brake lever and releasing it to allow spin action. So check the release of the brake. Tony the technician down under....
Apr 02, 2011 | Washing Machines
I have a Smart Drive Fisher & Paykel 7.5 washing Machine and my darks come out of the wash with hard to remove fluff
Hi just read your posting.Now you need to remove the bowl and give the bowl and tank a good clean.1st remove the 2 screws under the lid that are hidden under 2 plastic caps at the front of the machine.Now lift the hob gently and lean it back against the wall.Now remove the agitator cap and undo the plastic wing nut inside your agitator.Once the wing nut is removed lift the agitator out of the bowl and put it on the ground.Now grab the inside of the bowl with a hand on the left and a hand on the right and lift the bowl gently out.Take the bowl out side and clean it with a hose and brush.After the bowl is clean it is the tanks turn to be scrubbed and cleaned.Use hot water only and a brush to clean the tank.Do not worry about the water getting into the tank as this will drain out once the machine is put back together.Be careful not to splash any water on the electronic buttons.Once the tank is clean and the dirty water is at the bottom of the tank refit bowl and agitator with the wing nut.Put the hob back down on the frame and refit the 2 screws and plastic caps.Now turn the power on to the machine and select a spin cycle and push the start button.The dirty water will now drain out and job done.Now you can use the machine as normal.Hope this is helpful and if you need further assistance feel free to reply back as I always check my profile for people who need help.Also if this helped could you please reply with a comment and a rating so I know I am making a difference.God luck with the machine and bye for now.
Oct 05, 2010 | Washing Machines
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
In the spin cycle, my washers agitator spins but not the drum. Aren't they supposed to spin together? Also alot of knocking or clicking noises
yes in the spin cycle the agitator and bowl lock if not clothes ball up and machine goes out of balance check the spin coil or electric damper is activated during spin cycle if not replace if blown or open circuit also clutch arm cold be broken have a close look keep me advised
Nov 05, 2009 | Washing Machines
Hi.I have a Gentle Annie that starts and stops filling with water
It is most likely the lid switch. The switch sits in a plastic bracket which has a lever coming down behind the tank.
If the tank sways and hits that lever, it cuts off the cycle as a safety measure. When the switch is faulty or more often when the plastic bracket breaks, you get this symptom.
Let me know if you need more assistance.
Ash
Oct 22, 2009 | Fisher Washing Machines
Eco smart won't drain, smells hot
hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
Oct 19, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
