Question about Transcend T.sonic 610 MP3 Player
My mp3 player does not get formatted by windows and its showing 0 space used and 0 space unused of memory, how can i fix this problem?
  • 17,130 Answers
Connect your device to the PC, click the start button and select the search window, then select the device the Mp3 player , search for all files by clicking with a' * ' you will then get to see all files, delete off or save all and then format. I hope this helps you out. good day.
Posted on Jul 05, 2010
I have problem with my mp3 player. when i plug in it shows removable disk with no space. 0 bytes 0 memory.
You most likely have an internal 'format' media problem with your mp3 Flash memory: if you can see your files while plug-in, would first back them on your PC (if possible) before performing a 'low-level' format or your MP3 media using your Windows disk utilities or more likely using a utility such as 'Flash Memory Toolkit': I would suggest that you get an 'expert' friend to do it for you if you are not sure.
Dec 19, 2009 | Transcend T.sonic 612 MP3 Player
I have a scandisk pen drive it show free space 0 kb and use space 0 kb and shows disk unusable plz help
Format the drive by right clicking on its icon and selecting format. Once in the format window, click start. This will take a few minutes and will check the disk for errors as well as format. If you encounter errors while formatting, it may be that the device is defective. Otherwise you should end up with a functioning pen drive.
Nov 02, 2009 | SanDisk Computers & Internet
Sandisk c200 / unable to recover unused space
try a hard drive recovery program,like partition magic or hirens repair disk,some flash drives need to be formated in fat16.not fat32,or ntfs,your computer cant do that,but the right software can,good luck hope this helps
Sep 14, 2009 | SanDisk Sansa c200 MP3 Player
Music missing space used up.
Try this.
Go to the SETTINGS tab and
select USB
Set the format to be MSC
(By default it will be in autodetect/MTP format)
*see the user guide
At least this worked for me.
May 11, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
My Scandisk Is a 8.0 and it says there is no memory.
Is this conected to PC if it is right click the icon for the scan disc then format it ... this works with lots of things that conect to pc.. I know you say its empty and why should you format but try it ;-) Hope this helps
Jan 13, 2009 | SanDisk Sansa Clip MP3 Player
Ilo
Although it should be letting you download more than 424mb of files, there are only 2 things I can suggest:
  1. Try to open up the folder when you plug it into your computer. Search through the folders and see if there are files in there that may not be compatible with your mp3 player and therefore will not display.
  2. Check for duplicate files and that the size of the files is not misleading. I've had a problem where a certain song was displayed as being 2.56mb, I opened it on my computer before it was transfered and it was registered as 60mb because the track would continue to play for hours afterwards because of the file being inappropriately labeled at the ending point.
The fact that there is so much unused and unusable space on the mp3 is unusual, but you may have a problem also with your formatting. You DO have to leave some space in your mp3 player to leave room for the operation files of the mp3, so although it is labeled as having 2gb of space, you have to save at least a couple mb of space to let the system function. Hope this helps.
Jun 12, 2008 | iLO (2 GB) MP3 Player
NWZ 615F Blk MP3 player
 “I can’t load any more songs into my mp3 player” or “An incorrect number of songs show up.” (MEMORY/FORMATTING ISSUE)
Sometimes, you can’t load any more songs into your player because, well, there just isn’t any more space left on your player.  Mp3 player product documentation does not actually list the actual amount of memory that you can use in your player, and it doesn’t list the actual number of songs that you can realistically fit on your player.  Every mp3 player needs a certain amount of memory space to operate and firmware upgrades decrease this available space – so, your 2GB mp3 player actually contains only 1.7 or 1.8 GB for music and other media files.  The mp3 player that says “can hold up to 1000 songs” may only hold 400 songs – the product documentation assumes that you are loading a 1-minute song in the lowest possible quality format – not very realistic.  A single 30-minute audiobook, speaker file, or video can seriously bring this number down.
Other times, however, you are experiencing a formatting issue or memory corruption.  If you plug your mp3 player into a computer that has an NTFS file system, and then plug it into a computer that has a FAT32 file system, you may experience this formatting issue (file system/formatting issue).  Similarly, this will happen if you plug an mp3 player into a computer running Windows Vista, and then plug it into a computer running Windows XP (operating system/formatting issue).  Or, if you plug your computer into a PC, and then into a MAC (PC or system/formatting issue).  Or, if you plug it into a computer with Windows Media Player 10, and then into a computer running Windows Media Player 11 (software/formatting issue).
Apparently, if you add too many folders, especially via Playlist, via Windows Media Player, the Mp3 player's file system will become unstable - it can only handle a certain number of additional folders. To resolve the issue:
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Now, when music is transferred, it will be placed in the root directory of the flash memory disregarding the folder structure and allowing all tracks to be seen.
This procedure was designed for Siren Mp3 players, but is applicable to many other Mp3 players. It is not a guaranteed fix for every Mp3 player and every error of this type, but it is certainly not a widely known or reported solution.
Before proceeding with a format or reformat of your mp3 player, check with the manufacturer first.  On many players, a format or reformat along the lines suggested here will override your mp3 player’s native formatting and render your player unusable.  Transcend’s T.Sonic player is especially susceptible to this problem, and should never be formatted.  Also, the instructions below are for Windows-based PCs, not for Macintosh.  There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in some cases by updating the player's firmware or reloading the firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Mar 17, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
RCA 1501 memory full
New Players have a format selection on their settings menu, it you find it select it, Certain MAC OS computers do not format thing right. If your player does not have a format button, use a windows computer. Your hard disk might (the mp3 hardisk) might have corrupted
Mar 05, 2008 | Audio Players & Recorders
Internal memory and fomatting problems
Here you go http://www.mympio.com/index.php?topic=15.0
Apr 18, 2007 | Mpio FY500 MP3 Player
Abaut firmware
Have you tried formatting it.
Jun 19, 2006 | Teac MP-111 MP3 Player
Transcend T.sonic 610 MP3 Player Logo
111 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
