It is a common problem with them.Every couple days,remove the battery for a few min.and let the phone reset itself.You also should shut the phone off a couple nites a week.And remember not to over charge it.It is never a good idea to leave them on the charger for more than a few hours at a time.I was having the same problem with mine,And now it seems to be fine
thanks
Hi,when a phone does not come on, it is either the battery of the phone
is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to
be restored
back the phone memory.
will need to be flashed.
when a phone won't turn on and blinks red light, it 's either the
battery cell
if too weak to power up the phone all application you downloaded on the
phone has
VIRUS and has affected the phone memory.
First Charge the battery forlonger hours before using another battery to
confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it
to come back to life.
You can use the link below to know about how to flash the phone.
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
