Question about Garden
It keeps wearing out the upper deck belts and also snaps the shoulder bolt on the tension arm.
  • 760 Answers
You didn't indicate what model of tractor you have. usually if you're eating the drive belts there is a problem on how they are installed. Make sure the belt is correct belt and not too long or too short. Without model number it would not be possible to show a diagram, but typically the belt should go around the drive pully about 180 degrees, When the tensioner is tight the belt should not rub on any guides, or bolts. It should only ride on the pully, and the flat side of the idler(s). The other posibility is that one of your spindles has bad bearings, causing extra strain on the belt or if it's "locked" up then it will burn right through the belt. If there is a cover over the belts ( and there should be) make sure it's not rubbing the belt.
Posted on Jul 05, 2010
I have a huskee lt 4200. I keep buying deck belts for it but it keeps eating them up. The tensioner pulley is engaging but the belt flaps around real bad. Ive replaced cable. Caint figure it out.
Clay it may be time to replace the pulleys,including the engine pulley, check all bearings and blade spindles for wear and free movement and if the tensioner is on an arm lube the arm so it move freely.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why am Breaking So Many Belts on My Mower
http://www.tractorforum.com/f166/burning-up-deck-belts-21199
Craftsman lawn tractor breaking belt after each use
Why Does My Yard Man Mower Keep Destroying the Belt That Is on the Deck to...
Jun 05, 2016 | Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
1997 Jeep cherokee larado squeals replaced the drive belt a few times and it keeps tearing
Inspect the belt tensioner for the following conditions:
Noise
  • If the belt squeals, the tensioner force may be insufficient. Check the belt length gauge, if the length is correct, replace the tensioner.
  • If the tensioner clatters or rattles during engine operation, there may be internal interference or wear. Replace the tensioner.
  • If the belt chirps, you may have a worn pulley or tensioner or cracks in the tensioner bas or arm. Check the mounting bolts, if they are okay, replace the tensioner.
Sticking or Seized Tensioner or Idler
  • If the tensioner does not operate smoothly or doesn't move, you may have: internal thrust surface damage/wear, internal damage/wear, or a broken spring, replace the tensioner.
Appearance
  • Inspect the tensioner arm for cracks or other damage. If the tensioner is broken, it should be replaced.
  • Look for excessive tensioner movement at idle, which can indicate internal wear, an out-of-round pulley or loose mounting bolts. Check the mounting bolts, it they are in good condition, replace the tensioner.
  • Make sure the tensioner is not tilted or misaligned. Also make sure a gap exists between the tensioner arm and base. If you notice a problem, check the mounting surface, it the surface is okay, replace the tensioner.
Belt Tracking
  • If the belt does not track properly on the pulley tracking surface, you'll need to troubleshoot the problem. Check the mounting bolts and the system alignment. Then, make sure the correct belt is being used for the vehicle. If all of these things are intact, replace the tensioner.
Belt Length Indicator
  • A belt length indicator is built into each tensioner.
  • The gauge identifies the effective operating range of the tensioner.
  • It consists of a pointer and either two or three length marks.
    • On a three-mark gauge minimum belt length, maximum belt length and ideal belt length are indicated.
    • On a two-mark gauge only minimum belt length and maximum belt length are indicated.
    • Ideal belt length on a two-mark gauge is generally half way between the minimum and the maximum.
  • When a belt wears and stretches with age the tensioner will move towards the maximum belt length to maintain proper tension.
  • As the pointer nears the maximum length mark, replace the belt.
May 04, 2012 | 1996 Jeep Grand Cherokee
I have a Sears Garden Tractor with a 48" mower deck. By working in long, thick grass I broke the mower belt -- not the one that transmits power from the engine, but the belt that sits in a pulley on...
I believe that tensioner pully has to be loosend up and moved.
Here are the instructions for this.
  • Place the deck in the lowest position using the hydraulic piston (if applicable) or the manual cutting-height adjuster.
  • 2
    Remove the deck-to-PTO belt from the PTO by releasing tension on the idler-arm pulley. This is a spring-loaded handle that turns in only one direction by hand and relieves the tension on the belt. Slip the deck-to-PTO belt off the PTO pulley after the tension is relieved.
  • 3
    Remove the deck from underneath the mower or tractor.
  • 4
    Locate any belt stops and loosen them with the ratchet wrench and proper socket. Belt stops are located on the deck and are the small metal brackets that guide and secure the belt to the pulleys so it will not jump off when under heavy use, or stretch from normal wear.
  • 5
    Remove any pulley covers by removing the retaining screws using the ratchet wrench and a socket.
  • 6
    Loosen the idler-pulley retaining bolt (located on the underside of the mower deck) to replace the deck-to-PTO belt. Removing the bolt is not necessary. Loosen the pulley enough to wiggle the belt free from the pulley and remove and replace the belt.
  • 7
    Remove any arbor covers (if applicable) that conceal the arbor pulleys by removing the retaining screws with the ratchet wrench and a socket to replace the mower arbor belt.
  • 8
    Locate the tensioner pulley on the mower arbor belt to replace it. Loosen the tensioner pulley bolt enough to slide it and release tension from the belt. Remove the belt from the arbor pulleys and replace it.
  • 9
    Slide the tensioner pulley back leaving about 1/2-inch of play in the belt and tighten the bolt. Reverse the procedure to put the rest of the mower deck back together and reinstall on the mower or tractor.
  • May 10, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    Need to replace Serpentine belt and p/s belt on my 2002 honda odyssey is this complicated?
    the procedure is as follows:-- You have to do it from underneath the vehicle. Take off the rivets to the two plastic covers, and then you will be able to see the tensioner for the belt. Use a 3/4 inch wrench on the tensioner (don't put it on the bolt that holds the tensioner on), and pull it toward the vehicle. The belt will loosen, and you can take it off. As a car owner, you know how important the belt tensioner is for your 2002 Honda Odyssey. However, internal parts wear and damage will loosen or seize the tensioner wheel, causing the belt to slip and make noise. Eventually, the belt may break, shut down the engine and lead you into a serious traffic accident. Before that happens, replace the tensioner on your Honda model and save yourself a lot of problems:---- Remove the Drive Belt:-- 1)Look for the drive belt routing diagram on your vehicle's engine compartment. This is a black and white label, about 4 by 6 inches, usually attached to the radiator shroud or near the strut towers inside the engine compartment. This diagram will be your guide when reinstalling the drive belt. If cannot find one, make a simple sketch on a piece of paper. 2) Insert a belt-tension release tool, or similar tool, into the auto-tensioner arm. 3)Rotate the auto-tensioner arm counterclockwise and slip the belt off the tensioner pulley. 4) Release the auto-tensioner but do not let it snap back in place. 5) Remove the drive belt from the engine compartment. Replace the Belt Tensioner 1) Unscrew the two auto-tensioner mounting bolts using a ratchet, ratchet extension and socket. Note the location of each bolt because they are of different size. 2) Remove the old auto-tensioner from the engine compartment. 3) Set the new auto-tensioner in place and start the two mounting bolts by hand. Make sure you install the bolts in their original place. 4) Start tightening the bolts until they hit the stop using the ratchet, ratchet extension and socket. 5) Torque the two bolts using a torque wrench. Torque the small bolt to 16-foot pounds [22 Nm] and the large bolt to 47-foot pounds [64 Nm]. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
    Mar 01, 2010 | 2002 Honda Odyssey
    Belt keep coming off cub cadet 1042, all parts on deck have been replaced with new parts & still the belt comes off every time
    my cub cadet used to throw the cutter belt too....till i took the drastic step of adding a bit more tension to the belt. this was achieved by drilling another hole on either side of the chassis about 1 3/4 inches to the rearward of the machine and moving the lift arms to the new holes. Viola, more belt tension, and furthermore there is now no interference between the tensioner and the rearmost run of the belt.
    Oct 22, 2009 | Garden
    MTD Lawn Tractor: Constantly shredding deck belt...
    I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
    Jun 05, 2009 | Mtd Garden
    Seat Belt repair/replace
    1. Remove front seat.
    2. Remove adjuster cover. A
    3. Slide floor anchor cover.
    4. Remove floor anchor bolt. B
    5. Remove shoulder anchor bolt. C
    6. Remove front and rear kicking plate, then remove center pillar upper and lower garnish.
    7. Disconnect seat belt pre-tensioner connector.
    8. Remove the screw securing seat belt pre-tensioner retractor, then remove seat belt and seat belt pre-tensioner retractor.
    9. Remove bolts securing seat belt adjuster, then remove seat belt adjuster. Reverse procedure to install.J
    Nov 03, 2008 | 2000 Nissan Maxima
    Garden Logo
    42 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
