Can't find the files on my hard drive - Computers & Internet
  • cjmunitz Apr 17, 2008
    yes
    basically the amount of space is used up but i cant find the files anywhere
    i have a 200gb hard drive about 180 is used but i cant find my files
    Guru:
  • 1,463 Answers
Which files?
have you tried searching for the file name's or by file type / date etc.
riz.
Posted on Apr 17, 2008
What does it mean when my saved files on my hard drive are no longer viewable on my Laptop (acer) I'm currently accessing my saved files on my hard drive via the 'recent places' in the 'Favourites' op
try manually looking for the files in the drive or have windows look for them for you long as the windows index system is running you maybe able to find the files your looking for
May 26, 2014 | Imation Apollo UX 2.5" USB Portable (250...
Need to transfer files from old computer to new Hitachi 3 terrabyte drive
The need to transfer files from one hard drive to another is common when restoring from backup, to make more room on a drive by archiving files or to copy or move files to a portable hard drive. Whether the destination drive is an installed second or third hard drive or is a portable hard drive, the procedure to transfer files from one hard drive to another remains the same.
Plug the destination hard drive into the computer if the drive is portable, and confirm that the computer has recognized the hard drive with a pop-up acknowledgment message. Click the "Start" button then click "Computer" or "My Computer," and then double-click on the icon of the hard drive that contains the files to be copied. When a window appears displaying the contents of the hard drive, navigate to the location of the files to be transferred. Click on each file to be transferred while holding down the "CTL" key to select all files to be copied. Right-click on one of the files that has been selected and click "Copy" in the menu that appears if you wish to leave a copy of the files on the hard drive, or click "Cut" in the menu that appears if you wish to move the files instead. Double-click on the icon of the destination hard drive in the "Computer" or "My Computer" window to display the contents of the hard drive in a new window. Navigate to the location on the hard drive where the files are to be saved. Double-click on the destination directory to open the directory and then right-click on blank space inside the directory window and click "Paste" on the menu that appears. A window will appear and display the status of the file transfer and disappear when the file transfer is completed. Hope this helps.
Jan 07, 2013 | Computers & Internet
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Oo.comhi. if i delete my files from SDR-H85 PANASONIC how i will recover back without problem. i did with one program but didnt help.
http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
Supported file systems:
NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media. hope this helps
Apr 10, 2011 | Panasonic SDR-H85 Silver 80GB Hard Disk...
Unable to access files
To access the files off the hard drive another way - remove the hard drive from the case and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. If the computer see the hard drive as an external hard drive/storage device and you can open the folders and files then backup your data. This also indicated the hard drive is OK and the Western Digital case/electronics is faulty.
To use this as an external USB hard drive, put the hard drive in an USB adapter case.
Sep 09, 2010 | Western Digital 320GB MyBook External USB...
Files disappearing on external hard-drive (nexstar.3)
In this case you should use data recovery software to try recovering the files and data, provided those lost data are not fully overwrtten.
Be careful: Before your files are recovered, do not attempt to save more files to the external in case the original files are overwritten.
Feb 21, 2009 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Files won't open on external hard drive after it fell 18 inches
ooo I have the same prob but mine.. the computer just doesnt recognise the external drive at all well if u find the solution plzz helpp...thnxx i hav evrythin on itt nd i need themm...
Jan 02, 2009 | Western Digital 500GB My Book World...
PAGING FILE ERROR ON HARD DISK DRIVE
You don't install backup files; they're just files.
What you want to do is back up files to a portable hard drive. Then you want to find the backup files on your D drive and delete them.
The biggest commonly available flash drive is 8gb. That's enough to back up your word processing documents and such, but not enough to back up your entire computer. It's may not even be enough room to back up just your music files.
A 1tb external hard drive runs less than $150 now, mail order, delivered.
Dec 05, 2008 | Microsoft Windows Vista Home Premium with...
My maxtor external hard drive has done a scheguled Plan b backup but files that I removed from my master hard drive to free up space because I had them saved on my external hard drive are now missing from...
When a file is delete, it's still there on the drive, just as before; all that happens is that the file table marks it as free space and changes its name so it's no longer visible. There are a number of "undelete" utilities available, including several good ones, like asoftech data recovery that helped me before:
http://www.asoftech.com/adr/
Nov 24, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
