Question about Mitsubishi WD-65731 65" HDTV
Channels lock when we turn to channels that are rated r or pg 14 i tv screens goes blue and asks for code we havent put a code in and do not no how to fix this please help thaks candee
  • 58 Answers
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and QV
buttons on the TV remote control at the same time. This
process temporarily unlocks the TV
When entering the Parental Lock menu, this process
deletes your old pass code and prompts you to enter a
new pass code. Press EXIT to exit the menu.
Posted on Jul 06, 2010
How to remove pg-14 channel lock?
unplug tv for 30 secs and your new code will be 0000
May 22, 2015 | Sylvania Televison & Video
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
42 inch flat screen shows v-chip block tv-14 lsv what does that mean? tv fades tremendously turns blue then shuts off
V-chip Block
TV- 14 - this is a rating for movies and TV programs. Basically means PG-13 like the old movie theater rating.
lsv- means, language, ***, violence.
You TV can be set to block these programs.
In you menu look for a catagory called "locks" or "ratings"
there you will find the options of what can be veiwed and what will be blocked.
if you everything to be available, just disable all settings.
if you want to choose different things to be allowed, just click on the icons and they become blocked.
Apr 12, 2011 | Olevia LT42HVi 42 in. LCD Television
AFTER TURNNING TV ON 2HOURS (+OR-) THE SCREEN GOES BLACK ON CABLE STATIONS AND THE FOLLOWING APPEARS ON SCREEN ------- PROTECTED PROGRAM BY TV-PG ------ WHAT STEPS MUST I TAKE TO CORRECT THIS ON MY TV ! ...
The parental control or V chip settings are turn ON. I would suggest to find it in the menu and turn it OFF.
What is the model number of your TV?
Dec 20, 2010 | Televison & Video
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Turning parental control blocks off
Parental locks are put in place to stop minors from accessing usuitable programs. An adult usually selects the channels to lock out as well as categories of videos that can be played. Thesae are controlled by a code neterd by the Parent or Giuardian and cannot be subverted without knowing the code. I am tempted to say.... ask your parents for permission to unlock this. We cannot supply any information without proof of age here.
With this model also there are no secret codes listed to over ride an entered password as its not a regular brand of TV. maybe the people you bought it from ( Walmart?) may be able to contact the supplier who rebadged this unit, to help you overcome the problem
Sorry we cant be of more help for you. Please accept our apologies
Thank you for using FIXYA
Sep 25, 2009 | Prima C2012 TV
Mitsubishi WD-65731 65" HDTV Logo
141 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
