Question about Yamaha RX-V490 Receiver
My music only plays out of the 2 left speakers and not the right 2. It worked for a little while but now it's only the left. At first I thought it was the aux cord but im pretty sure it's not. Do you think my right fuse is blown out or something?
3 Suggested Answers
SOURCE: sound
I have this same problem, help!
Posted on Jan 07, 2008
dunnbiker
  • 8546 Answers
SOURCE: i was told i might
There's no separate fuse for test versus operational speaker function.
Evaluate the source for why the "3 left" speakers (whatever that means) don't work for program material.
Posted on Jun 27, 2011
Right speaker terminal not working - tested out both speakers and they work fine when independently tested on the left speaker terminal. Sony MHC GX45 Shelf System, 2 speakers and 1 sub.
If the sound is also dead on that channel on a pair of headphones. Then you have probably lost the main power amp for that channel. To be certain. With you headphones on, slide or turn the balance control so you can only hear the faulty channel. With some music playing turn up the volume. If you can hear "faintly" music playing then the pre-amp is OK and the power amp has gone.
The power amp will be located on a heat sink. It will consist of 4 transistors (2 for each channel) or one big device (or two) (an IC). If it is transistors you only need to replace the two for the right channel.
Aug 31, 2013 | Sony COMPLETE PWB, MP-45 Shelf System
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
Jan 05, 2012 | Nokia 5700 Cellular Phone
I have an old Sony SAVA100 that after a move the left speaker would not turn on giving me no sound. I did a factory reset and now I get sound but only from one speaker. If I hook the RCA (Red and White)...
hi the speaker wire or the plug has become disconnected, this can happen sometimes when moving from one place and moved by vehicle, put the tv down flat on the ground screen side and remove the stand then remove all screws around case. life the back off and on the speaker check it from there to the board, push the connector back on, and with a bit of isolation tape put some over the connector. if it has a female connector to male bend the round parts down with a pair of plyers so its a tight fit to the male connector. refit case in revers order.
Jun 02, 2017 | Sony SA-VA100 System
I have an mp3 player that i want to hook up to my logitech x-540 speakers but when i do it only plays on the front, or rear speakers depending on which cord i plug it into, is there a way where i can use...
An MP3 player is a stereo device, meaning that it works on two channels - left and right. Therefore a 5.1 speaker system will only play on 2 speakers.
However, if you want to use rear speakers as well, just for the fun of it (you won't get any surround effects, both left speakers will play the left channel, and both right speakers the right channel) you can purchase a "headphone Y-adaptor", that normally allows two people to use two pairs of headphones on the same portable music device.
It has one headphone plug and two headphone sockets in parallel. Plug it into the player, and to the sockets plug the front and rear speaker cables :)
Please come back with a testimonial if helped :)
Dec 22, 2009 | Logitech X-540 Computer Speakers
Problem with left side of all audio
Have you checked the balance foe left to right if it's full right no music will play through the speekers but you will still get the beep and other sounds like that that should be where you chand bass and treble settings along with fade center it and you should be good
Oct 04, 2009 | 2004 Nissan Sentra
5.1 speakers dont work right on sound blaster card
Most music does not put out sound from the rear speakers. Test it with a DVD, most of them use the rear speakers for some sound effects.
Feb 22, 2009 | Creative Labs Sound Blaster Live! 5.1...
Amplifier balance problem
reverse your cable if the problem go to right speaker you have a problem in your amp and needs to fix-if the problem still in your left speaker you will have a problem in left speaker itself(cables or speakers)-start with cable changing and then speakers,
Jul 21, 2008 | Audio Players & Recorders
3 out of 5 speakers not working
my left speaker isn't working. I've check the connections. what can I do?
Apr 15, 2008 | Audio Players & Recorders
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Yamaha RX-V490 Receiver Logo
29 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
