Question about Cameras
My pictures a\have a very noticable purplis/green cast across parts of the image. Does not seem to be as noticable on all images.
I HAVE A OLYPUS FE-300. I NEED TO DOWN LOAD SOFTWARE FOR IT, OTHERWISE, I CAN CHARGE MY BATTERY, CAN YOU HELP
Posted on Apr 18, 2008
I HAVE A GR2 DIGITAL CAMERA. I usually shoot in manual mode and and set white balance manually using a digital callabration target. Yesterday afternoon, after shooting most of theday without problems, my...
I doubt that formatting the card will do anything but, if you choose to do that, download any pics first since formatting will completely erase the card. Have you tried going back to "Auto WB" to see if your camera works properly that way? How about going into the menu and finding "reset" to get back to factory default settings?
Nov 23, 2010 | Ricoh GR Digital Camera
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
Mar 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Displays green color image/screen
When did you get this message? It seems like you have set the White Balance of the camera wrong. Set it to Auto White Balance to eliminate this problem. Use Daylight White Balance when shooting in bright daylight so as to eliminate any color cast in the image.
Feb 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My connon powershot S500 has a dark haze or blur on have the the view screen and it is green
It appears that the image sensor (CCD) has stopped functioning. There is no fix for the part, only repair, and replacement of the part. If you perform an internet search, type in "bad CCD purple images", you should get several sites with the information in detail. Here's a link to some info also: http://www.paulstravelpictures.com/Canon-Powershot-CCD-Image-Sensor-Service-Notice/
May 05, 2008 | Canon PowerShot S500 IXUS 500 Digital...
How do I align the color on an MT850
Hi
pls check the board before the color wheel, as it is noticed that this problem comes with the main PCB Board.
Viren
Nov 19, 2007 | NEC MultiSync MT850 Multimedia Projector
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
YThe colors in my picture have yellow/green color cast.
When you take pictures under certain artificial lighting conditions- such as fluorescent, incandescent, or halogen lighting, the colors in your image may take on a yellow or green cast. You can use HotShots to touch-up the colors; see Chapter 7 for instructions.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Cameras Logo
57 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
