Fisher & paykel 501 smart drive washing machine
Fisher and paykel washing machine smart drive 501 wont start up. I had to unplug the machine for about 24 hours and then today I plugged it back in and the machine won't turn on at all. It's not the power outlet as have tested that with other things.
  • 712 Answers
It does not seem like a problem of the unit. It might be a loose connection of supply code. Keep the supply code pressed to the unit in different directions and see if the unit takes power. If so, replace the supply code. It's not that expensive.
Posted on Jul 05, 2010
Fisher and paykel smart drive 5.5 won't start a wash cycle, no lights flashing or beeping looks normal but won't start
Contact Fisher and Paykel Service Center and DO NOT TRY TO OPERATE THIS MACHINE UNTIL CHECKED & VERIFIED BY AUTHORIZED FISHER AND PAYKEL SERVICE PROFESSIONAL.
Apr 28, 2014 | Washing Machines
My F&P Smart Drive 501 will not start with power button. I have to set it to delay start to get a load to wash... any suggestions? thank you
The start button tac switch has been wet and need replacing.
a crack in the decal let water in on the button.
Put clear packing tape over any cracked buttons on your decal.
Jaycar Electronics have these tac switchers,
Take the old one with you to get the same size.
Apr 18, 2013 | Fisher and Paykel Washing Machines
Leaking fisher & paykel smart drive 501
Check your hot and cold hoses at the back for leaks,
these are just crimped on plastic ends and can crack and leak..
Jan 13, 2013 | Fisher and Paykel Washing Machines
Fisher and paykel kelvinator II smart drive 501 washing machine stops washing mid wash
Check the out of balance switch under the blue motor controller
for corrosion replace if corroded.
Sep 27, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel smart drive 9 mw059au no power
Most of the faults are pump related.
check the Ohms reading on pump should be 33- 35
If readings are less change your pump.
Jul 28, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
My Fisher and Paykel Smart Drive 501 toploading machine won't finish its cycle...it always gets stuck on the spin cycle and starts beeping. This happens every time not just occasionally. How can i fix...
need to have a look at the machine, how old is the machine 15 years roughly, Yes this is when the machine plays up, hard to find spare parts. If you are getting rid of the machine let me know. 0412676652 Since I want to learn fixing the machine, I did fix one of this model long time ago
Jul 01, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
Mar 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
776 people viewed this question
Top Washing Machines Experts
