Question about Euro-Pro F1066 Deep Fryer
Won't turn on
Washed & cleaned the fryer, did not get anything wet that should not be, will not come on.  Is there a relay some where I am not seeing?
loved the product. used it twice a week since we got it. made a second batch of chicken when it turned itself off. tried another outlet and waited for it to cool down. still nothing.
  • bearsie Jul 21, 2008
    When plugged in,the unit will not come on, when I press the minus side of the temperature button the red light comes on as I hold it, but the unit itself will not come on.
Yes there is. The heater assembly has some slides that must be inserted in the base for the unit to light up.
Posted on Jul 01, 2008
Bosch maxx Classic. 7 yo. Washing cycles are not finishing. Timer is showing 1 but does not turn off. Clothes are still quite wet. Have cleaned filter. Anything else I can do?
Looks like the solenoid that controls the drain motor is malfunctioning.
Whenever this happens, the water does not get drained fully and remains in the chamber thus keeping the clothes still wet.
Speak to your local service representative and get the part replaced.
Feb 22, 2015 | Bosch Washing Machines
My Breville BDF450 will not turn on (no lights no nothing). Heated oil up prior to cleaning. Cleaned and changed oil now unit will not work at all
Did you pour out the oil when it was still at it's hottest temp? I would guess there is a master overheat sensor that tripped off. It will be a little thermodisc with 2 power wires connected to it. Find and replace that thermostat sensor. You can test it for continutiy with a volt meter.
Dec 11, 2014 | Breville Deep Fryer BDF450
How to clean deep fryer
Hi There Best way To Clean Bella Deep Fryers Is To Use A Cleaning Product Called (Fry Clean) Its a Non Toxic Washing Liquid You Heat Up And Pour Out, Easiest And Safest Way Avaliable
Aug 01, 2014 | Bella Kitchen Appliances - Others
Pilot light won't turn off
Any parts been changed? valve might be wearing out.
Apr 23, 2013 | Imperial IFS40 Deep Fryer
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
My deep fryer pilot somtimes goes out after burners ignite
I assume this is a natural gas fryer....Are your jets clean? That is an issue sometimes, and those are the small holes that your flames come out of....Is your gas line clogged anywhere....? I don't sell Dean fryers, not too impressed by that brand, as they leak quite often, and then Dean won't honor their warranty program....so I'm not as familiar with their products, however on some brands, the thermostat dial itself should not be turned to the holding temperature until after it lights and is fully on...Do you turn it to say 350 degrees right away or wait for it to light before selecting your temperature? Thermostats themselves going bad is the number one issue with fryers, so it could be that. To clean out the burner jets, we use a compressor and blow them out clean...You can also use a small brush or skewer to clean them out. I would eliminate everything you can that has no costs involved first, and then move to parts that you have to purchase. If you need a thermostat, I could get you a price on Monday... Our toll free number is 888-542-5959, Restaurant Equipment Outlet, Cincinnati, Ohio. We would need the brand/model number and serial if you have it also. Our service tech who specializes in gas products is off Monday, but there are other people there who can help and get you pricing on parts. I won't be in until after lunch myself Monday, but check out what you can, and if nothing works, then call us on Mon or Tues next week.
Everything is closed up until Monday, so we can't order or get pricing over the week-end. Good luck, hope this helps.
Susan
REO
Nov 22, 2011 | Frymaster Dean SR42G Deep Fryer
Fryer wont turn on since I cleaned it
I don't service home models, only commercial products, however I would guess that something got wet somehow? Let it dry out for a few days and even a week or so, and then try it. If not, I would junk it and buy another...
Susan
REO
Nov 17, 2011 | GE 168997 Deep Fryer
Two imperial isf40 fryers taken apart and cleaned, inside did get wet. Now trying to light them both and neither will light and no gas getting to pilot light but gas is for sure working up to the unit.
Disassemble the pilot light tube and blow out with clean compressed air from a compressor.
This should get rid of any residual water in there that is blocking the pilot light.
Also, check the thermocouple if so equipped to make sure its tip is in the flame once the pilot light tube is cleaned out.
Good luck on this repair.
Oct 28, 2010 | Imperial IFS40 Deep Fryer
Won't turn on
We have an F1066 and the same thing happened. My wife washed the heating elements and did not get water in the electronics but for some reason it would not come on.
After sitting for about 24 hours, it finally came on. I dont know if it was condensation that got in there or was it just that she accidentally got water on it but it worked fine after that.
Oct 31, 2007 | Euro-Pro F1061 Deep Fryer
Cleaning
From http://www.rivalproducts.com/help.aspx?helpNav=1: How can I clean my fryer? - Unplug from outlet and allow unit to cool. Always turn control to OFF then disconnect plug from wall outlet BEFORE disconnecting BREAK-AWAY CORD. - Clean the outside of the fryer and lid with a damp cloth. CAUTION: Do not use abrasive pads or alcohol to clean the fryer. - Remove basket handle, if one is included. Frying basket can be washed in hot soapy water. - Rinse and towel dry carefully. - Pour out oil and discard properly. - Wipe the inside with paper towels to absorb excess grease. Wash interior of fryer with hot soapy water. Rinse and dry thoroughly. CAUTION: Never immerse the fryer in water or wash in running water. If you own a fryer with a removable bowl or other removable parts, refer to the Owner?s Guide for your specific fryer to determine which parts can be cleaned in the dishwasher.
Mar 08, 2007 | Rival CZF630 Deep Fryer
Euro-Pro F1066 Deep Fryer Logo
130 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
