Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Model PSC23SGRDSS ge Profile Arctica Side by side the dispenser is not working. Will dispense water only but sometimes will not turn on in order to do so. Ice dispenser is not working and the push panel is somewhat damaged causing a short????
HVACRH20
  • 237 Answers
SOURCE: GE PSC23SGRDSS Icemaker not working
Take the ice maker out and pull the square cover off of it. If you have the type with a plastic "gear" (about the size of a half dollar) on it check to see if the tabs that hold it in place are not broken (it's common). The gear can get cocked or even fall off and that will cause the IM to stop working. If it's the type with a circuit board in it check it for loose connectors, etc. Both types have a thermostat in them to sense the temp of the freezer (must be about 15-17F for IM to work). It's rare that the t-stats go out but it can happen. The "motor module" is a high failure item (about $60 bucks and easy to replace). Let us know what you find.
Posted on Jan 14, 2007
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
Sea Breeze
  • 4655 Answers
SOURCE: The ice will not dispense from GE profile sid by
The problem could be as simple as the door switch for the lights because the door switch when closed turns the control panel on. Or the problem may be the control board. WR55X129 Control Board Thanks, Sea Breeze
Posted on Jul 23, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Posted on Oct 21, 2009
Testimonial: "new here--did not mean to rate you low..sorry!"
Water dispenser is not working. Ice dispenser is working
If your model is the PSS25MGMWW and the water dispenser is not workingthe problem is most likely the=> WR57X10026 Water Inlet Valve Most times the ice dispenser and water to the ice maker will continue to work properly while the half of the water control valve will fail and stop water to the dispenser or ice maker. Follow the instructions in the video and I will be here if you have questions, Thanks Sea Breeze
Sep 12, 2013 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
I have a GE Profile Arctica Side By Side refrigeratorand the water despenser is not working. I have narrowed the problem down to be a frozen waterline, but it is not frozen in the frezer door. The line is...
There may be an issue with the water dispenser line freezing in this model. The fix for it might be this dispenser water tube heater kit # WR49X10173. Hope that helps you out and best of luck
http://tclaundryrepair.com/
Feb 25, 2009 | GE Profile¿ Arctica® Energy...
Water Dispenser works intermintently, Ice dispenser never works
Called GE Service Dept. My refrigerator was way out of the warrant period. They came out and replaced the main circuit board at NO CHARGE.
Jan 12, 2009 | GE PSW26SGRSS Side by Side Refrigerator
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
181 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
