Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23425
Freezer model 25324452104 Kenmore, light inside is on, but it does not freeze the food inside, also there is no noise of motor running
  • 1462 Answers
SOURCE: kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Posted on Oct 16, 2008
vanni7
  • 163 Answers
SOURCE: Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Posted on Jan 21, 2009
TheMobilian
  • 8220 Answers
SOURCE: food thawing in freezer
You may have a small leak in the evaporator. You could try to get a replacement freon with stop leak from the automotive store and give it a shot. If it is a R12 unit then it is too old to repair. But it is worth the gamble to shoot it with freeze 12 or an equivilent before you condemn it.
Posted on Apr 11, 2009
  • 323 Answers
SOURCE: kenmore upright freezer no digtal light no motor running
This could be a bad controller since you had a power outage, or even a bad motor. Look in your operator's manual and see if there is a reset button somewhere near the motor.
Unless you are well versed in electronics and have the proper equipment, you'll be unable to diagnose the control board anyway.
As a last ditch effort, which sometimes works, unplug it for about 5 minutes and then plug it back in. Make sure your thermostat is turned to the correct setting.
Posted on May 12, 2009
  • 6 Answers
SOURCE: My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Posted on Jun 14, 2010
16 years old. cold inside, but not freezing food. making small rattling noise
check the RepairClinic site, as they indicate what may be wrong when there is a 'rattling' noise in a freezer
Jan 13, 2016 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
25328782800 freezer not freezing 2 lites blinking
The problem your refrigerator has sounds like a 297370602 Main Control Board
Can you unplug refrigerator and go into the control panel inside the fresh food section? Examine the board for burn marks and swollen capacitors. I will be here if you have questions, Sea Breeze
Feb 08, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not freezing
If you can hear the motor running it could be the thermostat that has gone or if there is no noise at all it could be the motor that has died, a good easy fix ( sometimes works ) is to turn the freezer off leave it for 24 hours with no power then try turning it on again.
ThanksTalkAppliance.co.uk
Apr 22, 2012 | Kenmore Freezer 20.6 cu. ft. Upright...
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Upright freeze made a popping noise like a thermostat
If you heard the noise at a fairly routine rate and time it was probably the defrost timer motor. Locate it and you should be able to engage it manually. It is a plug and go part to replace. Be sure to take the old one along with the make n model # with you to the parts house!!
Jan 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer wont freeze - digital display has no display at all -
Melanie--
Because this occurred as a result of a power outage, you need to check that the outlet is OK. Plug something in the outlet like a lamp and see that it works normally. If that is OK, check the display for a light bulb that is burned out--incandescant bulbs do that occasionally in a power outage. If it is an LCD or LED display, the power supply is bad on the display board. Is the motor humming and making normal noises?--and your freezer is just not cooling? If no motor noise, look for a reliable and trustworthy appliance repair person. If the damage is costly, try to pursue a claim with the power company.
Dave M
Dec 17, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23425 Logo
108 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
