Question about Dmm Vision Fitness T9500 Treadmill
I am getting a noise that increases with speed. I replaced the front roller so it should not be bearings. It is a growling noise could the motor be the problem? I have a Vision T9500 Ortho and I use wax to lubricate the belt. It has about 150 hours and 650 miles of use on it. It is about 4 years old.
  • 9 Answers
Have you removed and cleaned the wax buildup off the rear roller? typically with the wax lubricant it will cause chunks to get caught in the rear roller and the grumbling sound is normally the irregular belt position as the wax buildup lifts and stretches the belt in places that it shouldnt.
Posted on Aug 05, 2010
Thumping from motor reebok treadmill
Seem like your front roller bearings are knocking. Remove the drive belt. Turn machine on. Replace roller if noise goes away with drive belt off.
Jan 02, 2014 | Reebok Competitor RT 5.1 SpaceSaver...
On my 2000 Dodge stratus SE I hear a Loud Growling/vibration noise on my car when speeding up or stay at a speed. when I turn Right I dont hear it its when I drive straight that i hear it. I took it to a...
Have you checked the REAR whell bearings? Sometimes even when the noise appears to come from the front, the rear bearing can be the ones. Happende to me in my older Spirit R/T. By spinning the rear Wheel with an old impulsor motor in a Wheel balancing/alignment shop, the technician showed me that it wasn't a front drive problema, but rear bearings getting some moisture inside and going bad. It made a worse glowl when turning to one side. Amclaussen.
Mar 06, 2013 | 2000 Dodge Stratus
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
Nov 12, 2010 | Epic 425 Mx Treadmill EPTL88105 !
My new balance 1500 treadmill works great but the last couple days its starting to make a clickinng noise around the belt. It sounds like its tranfering from the motor area. The belt has never been...
It sounds like you have a bearing failing, either in the front roller or the motor. If it is the front roller it will be a dull "Clicking" noise, if its the drive motor it will be a growl noise. The growl will be so loud at top speed you wont be able to even talk over the noise. Remove the motor hood and this will help you determine the culprit.
Nov 04, 2010 | New Balance Balance 1500 Treadmill
NOISE IN THE FRONT LEFT WHEEL ON A 1999 SUBARU OUTBACK , BRAKES AND ROTOR HAS BEEN REPLACED
if the front brake pads,rotor and more importantly the caliper were all installed correctly, this noise is probably a front hub bearing that is failing. they will start a humming noise and then a roaring/growling noise the worse they get. is the noise rotational? by that it will get louder and higher in pitch as you increase the vehicle speed. get it checked out right away to avoid possible further damage.
Nov 06, 2009 | 2000 Subaru Outback
Low level growling noise at rt. front wheel increases with speed. No change if in or out of gear. Can start hearing noise begining about 38 mph. very slight vibration Car has 77,000 miles and is well...
first rotate the tires see if there is a change. If that does not have a desirable effect there may be a worn wheel bearing,take note if the sound or vibration gets louder as you turn a corner, try left turns as well as right turns if the noise increases it is a wheel bearing.
Sep 22, 2009 | 2004 Toyota Camry
Rotating wheel noise from front end
That is the bearings going bad on it.
May 24, 2009 | 2004 Toyota Sienna
Transmission noise (growl)
It is at least one of your wheel bearings. I had all four of mine replaced before 40000 miles I hope that it is under warrantee
May 10, 2009 | 2006 Pontiac Torrent
Dmm Vision Fitness T9500 Treadmill Logo
353 people viewed this question
Top Dmm Exercise & Fitness Experts
fretlessbass
fretlessbass
Level 1 Expert
Sportsmith LLC
Sportsmith LLC
Techmotionusa.com
Techmotionusa.com
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
