Question about Nokia 1650 Cell Phone
If 03 is the 7th & 8th in imei is it original or not?
  • 67 Answers
Yes it is original
Posted on Jul 05, 2010
How to tighten the bobbin thread
Hard to diagnose without the make & model.
Usually, thread tension is adjusted using the upper thread tension. Most of the time the bobbin tension is not changed unless the bobbin case is worn or using lighter- or heavier-weight thread.
There is a small skrew on the bobbin case that adjusts the tension. Be sure to mark on the bobbin case, with a permanent marker, where the skrew is positioned before making adjustments so you can return it to the original setting, if need be. Use a small skrewdriver and turn that skrew 1/8th of a turn clockwise. Retest. Repeat until the tension is where you want it.
Mar 16, 2016 | Sewing Machines
Tip
How to know if your if your cellphone is good or bad quality?
Guys i want to share ko if how to check if your cellphone unit that you have using is good or bad quality...<br /><br /> Press *#06# at and your imei will appear , check the 7th and 8th number from the start and then check it below the quality of your phone..<br /> <br /> 08 or 80- manufactured in germany which is faired quality.<br /> 02 or 20- means your phone was assembled in emirates which is very bad quality.<br /> 01 or 10- manufactured in finland which is very good quality.<br /> 00- means it was manufactured in original factory which is the best mobile quality.<br /> 13- means it was manufactured in azerbaijan, which is also a very bad quality ...<br /> ..<br /> Numbers 7 to 8 are the<br /> Final Assembly Code(FAC)<br /> <br /> 06=made in Flensburg,<br /> Germany (flare)<br /> 07=made in Flensburg,<br /> Germany<br /> 08=made in Flensburg,<br /> Germany<br /> 40=made in Easterinch,<br /> Scotland (UK)<br /> 41=made in Easterinch,<br /> Scotland (UK)<br /> 47=very popular fake<br /> IMEI,There are<br /> thousands of phones<br /> out there with<br /> IMEI=00000047000000<br /> 49=Was found on a 8700<br /> from China with Fake<br /> IMEI<br /> 67=made in Illinois, USA<br /> (most<br /> prototypes<br /> )<br /> 80=made in Tianjin,<br /> China<br /> 81=made in Tianjin,<br /> China<br /> 92=made in China by<br /> EASTCOM in Hangzhou<br /> 93=made in China by<br /> EASTCOM in Hangzhou<br /><br />i hope it will help you next time that you are buying a new cellphone for yourself..thanks for trusting fixya<br />
on Feb 12, 2011 | Cell Phones
Tip
IMEI NO
press "*#06#". if the 7th & 8th number is 0 & 1 then ur mobile is a original
on Apr 02, 2010 | Cell Phones
Check my nokia e63 original or duplicate
Note down the imei of the phone by typing *#06# and then checking the imei online at http://www.numberingplans.com/?page=analysis&sub=imeinr . If it returns e63, its genuine.
Jul 18, 2011 | Computers & Internet
Hand break light on constantly and giving out warning soundon passat
Usually means that ABS (automatic braking system) has failed, but could also be failure of
the switch that detects hand brake on/off.
Need year of mfr for your Passat, and exact model number & engine size.
8th and 10th digits of VIN will do.
8th digit = engine size
10th digit = model year
May 13, 2011 | Volkswagen Passat Cars & Trucks
Tip
Check the mobile Quality
To Know IMEI number- *#06#
If the 7th and 8th digit is 00:Best & Orginal
01 or 10:Good
02 or 20: Not Good
08 or 80:Bad
13:Very Bad
on Dec 03, 2009 | Cell Phones
Tip
Check Your Mobile Quality!
Press the following on your mobile *#06# and the-international mobile equipment identity number appears. Then check the 7th and 8th numbers:
-------------------- 1 2 3 4 5 6 7th 8th
Phone serial no. X x x x x x ? ? ? X x x x x x x
IF the Seventh & Eighth digits are 02 or 20 this means your cell phone was assembled in Emirates which is very Bad quality
IF the Seventh & Eighth digits are 08 or 80 this means your cell phone was manufactured in Germany which is fair quality
IF the Seventh & Eighth digits are 01 or 10 this means your cell phone was manufactured in Finland which is very Good
IF the Seventh & Eighth digits are 00 this means your cell phone was manufactured in original factory which is the best Mobile Quality
IF the Seventh & Eighth digits are 13 this means your cell phone was assembled in Azerbaijan which is also very Bad quality
on Aug 30, 2009 | Nokia 9500 Communicator
35296904020256601
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Jan 04, 2011 | LG GW300 Cell Phone
I purchase second hand n73 but in this mobile has fake imei so i want to install geniune & ORIGINAL IMEI can i do this if yes then how?
You cannot changed the IMEI number manually. You have to use a specific software and hardware to modify the number. The best option available is to get it done from a mobile repairing center or Service center, but you have to know the original number which is written on the battery compartment of the handset (labelled with the model number and RM type of your handset).
If you want to do it yourself, you have to know how to use the software like, Jaf box, UFS box etc.. and will also cost you more than the price of your handset (new n73 handset). So, I recommend you to visit a service center, tell them your problem and they'll do it for you, but they can change it into whatever they want, in order to get an original imei number, let them change it into the one which is printed on your mobile.
I also wonder how did you find out that it's not genuine.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 22, 2010 | Nokia N73 Cellular Phone
Need # of amps of fuse for Wurlitzer 4100 Series organ
That means it is 1/8th Amp fuse. So the info you have is the fuse you need.
The other fuse (mains) is a 5 Amp
Apr 23, 2009 | Audio Players & Recorders
Nokia 1650 Cell Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
