If I have a power cord(such as a laptop cord) that is plugged into the wall and not attached to the appliance(computer), will the cord still take up energy coming from the wall, even if not attached to it?
You will constantly draw power from the outlet. Though it may not be as much draw as if you were running a device on it. Try picking up the AC adapter one day when not plugged in to the laptop. It still gets hot.
On another note,
When using AC power you should ALWAYS plug it into the back of the device before plugging it into the wall outlet to avoid excessive power surge.
When i try to record the picture on my screen the image goes pixelated and the color turns to a Dark...
(More)
When i try to record the picture on my screen the image goes pixelated and the color turns to a Dark green if you could help me with this it would be great, im using the software that came with it, the software is WinDvr 3.
zenith analog-digital converter - I have an intermittent black box that comes up at random - the box...
(More)
zenith analog-digital converter - I have an intermittent black box that comes up at random - the box takes up over half the TV screen, and can happen on any channel. Can't make it go away - it comes in over the top of the Zenith's menu, and occurs when box is hooked up into TV's tuner as well as composite jacks. Any ideas?
hola.. tengo windows vista 32bit y baje los drivers y el software de la pagina oficial del Sabrent...
(More)
hola.. tengo windows vista 32bit y baje los drivers y el software de la pagina oficial del Sabrent TV Tuner / Video Capture Box USB 2.0 with Remote.. pero al conectarlo al puerto usb no me lo reconoce.. asi es que no puedo instalarle los drivers ... ahora como le hago para que me lo reconosca??
