Question about NEC Dterm DTP 16D-1 Corded Phone
Problem with Nitsuko TX-Z 284
Swithched power off. when swithched again phones do not ring. When we pick up the phone there is a dial tone but we can't dial out. There is a call transfer facility whcxih is working . In other words when someone calls after 10 rings the call is being transferred. Callers when call our line say they can hear that they got through and line is ringing but no one is answering. At our end we are not hearing anything thus we do not pick up.
Please help ..rgds..Bosco William
e-mail: bosco50050@gmail.com
tel.: +6016-2010304
  • 43 Answers
SOURCE: LINE 3 RINGS ON ONE PHONE- AND DOES NOT RING ON THE OTHER 3...
You will have to get into the programming mode and change Memory Block 4-01 for the port of each phone you want to ring. The corresponding light for the button is OFF for no ring, GREEN for ringing, and RED for delayed ringing.
Posted on Feb 12, 2008
  • 43 Answers
SOURCE: Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
  • 10 Answers
SOURCE: Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Posted on Nov 04, 2008
  • 7 Answers
SOURCE: We cant hear the phone ring in our office now!
Call your phone from another phone. Don't answer it. Press you volume up/down button. Up makes the ring louder and down makes the ring softer. I bet someone turned you ring volume down. Once it is set it stays there. God Bless. Jerry
Posted on Nov 28, 2008
Why my nitsuko tx serise nxe2464m tx extension phones are not riging
Ringing is assigned in system programming, either a tech or your office in house tech will need to make the change.
Jul 03, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Reprogramming speed dial on old Nitsuko phone
Helo libbyc,
What is the model of your Nitsuko phone?
Jul 25, 2008 | Lands Phones
How to recieve a fax ?
If your printer is connected to a modem make sure that the port has a dial tone. To check for dial tone, try to plug in a phone to the same port that you printer is connected to. If it doesn't have dial tone, you might want to check with your phone provider. Or you can plug in the printer straight to a wall jack.
Once the printer is connected to a line that has dial tone, you can then setup the printer to receive faxes. To set it up, on the control panel of your printer, press on Setup > Fax Setup > Ringing and Answering.
If you have an answering machine, set your printer to pick up 3 rings higher than your answering machine. If not, set it to pick up on the 5th ring that way you will still have time to pick up the phone if it's a voice call.
If you have a voicemail service from your phone provider, you'll need to contact your phone provider to get a distinctive ring feature. Once you'll have that feature, you can assign a distinctive ring to your printer. You can find that under Fax Setup > Ringing and Answering > Ring Pattern.
May 29, 2012 | Lexmark Interpret S405 Wireless All-in-One...
No dial tone, rings but cannot answer
Turn off the mains power at the base unit for a few seconds, then turn the power back on.
Feb 15, 2010 | Panasonic KX-TG1033S Cordless Phone
I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
Jan 21, 2010 | Vtech Cordless 6041 Phone
Exact same problem.
Is this a system phone?
It sounds as though your set is not programmed with a line appearance. and line preference is not set, this can be set for intercom, or a line or nothing when you pick up the phone. You can do a pick up code to answer until an appearance is programmed on your set.
Aug 05, 2009 | Lands Phones
How do you forward a phone call from this phone to a cell phone?
to forward calls...go to your phone service providers website and help section for complete instructions...
with most companies simply pick up the phone... wait for dial tone... press *72 wait for 2 beeps and enter the number (area code first) that you would like it to forward to...once you enter the number wait for the line to ring... once it rings and is answered you are all set!
if it doesnt ring or is in use.. try again within two minutes...you should hear two short rings if it is activated...
to deactivate call forwarding...
pick up the phone (in the office)
wait for dial tone and dial *73 or #73
you will hear two short beeps... it is then off..
Apr 10, 2009 | Panasonic KX-TS3282B Corded Phone
Phone Rings,but cannot answer
if there is no dial tone that means that the connection is not being made when you pick up the phone hence you cannot answer nor can you get a dial tone
the fact that the phone rings indicates that the land line is good so the fault is in the phone itself
Nov 06, 2017 | Panasonic KX-TG5652 Twin Cordless Phone
Answering phone system cannot handle nuisance calls
i have problem with my phone (TX TCA115UA B)
i can not turn on the tone regime (now is on pulse regime when i dile the number)
Feb 05, 2008 | Panasonic KX-TG5632 Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
78 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
