Front-load steam washer smells like a stale sponge. How do you repair this? It is only a year old and was very expensive. The dryer works fine. Baking soad, vinegar, none of this helps. Thanks.
  • 4,059 Answers
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Posted on Jul 05, 2010
Obnoxious smell from washer
I use "Affresh" every couple of weeks to keep the washer smelling good. Here is the product to order.
Nov 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
Smell of stale water from Avanti compact washer
It may not be draining very well.
I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.
I also add vinegar to most washes but that's due to my teenage son's athletic wear.
Both those things do the trick.
You shoudl probably check the mechanics as well but the above is a stop gap.
Sep 14, 2012 | Avanti W789SA Top Load Washer
My dryer smells like an old wet wash cloth. It has a stale water smell to it and is making my clothes smell like it. I can smell it when i open the door and stand right in front of the dryer opening. the...
There is a very simple way to get rid of unwanted smells. I would suggest use a cup of white vinegar every wash to clean from stale muck and smells inside the machine.
Jul 24, 2017 | Dryers
My Samsung front load washer, which is about 1 1/2 old, smells like mildew. I've read that people put bleach in the drum and run it on a maintanence cycle and I'm wondering how I do that. ...
I had this problem too---same washer. The rubber door seal often harbours moisture and it's hard to clean just by running a cycle. You'll have to scrub away the mildew by hand.
Get a pair of gloves, a soft sponge, and a bucket of hot water with soap and bleach. Open the door. Press the sponge into the folds of rubber where the moisture is trapped. Work your way around the circumference of the seal. Repeat until the black goo is gone. Finally run a rinse cycle with some bleach.
Avoid this in the future by leaving the door ajar when not in use. Tuck an old towel into the seal to wick away the water.
Let us know if the smell is still there.
May 20, 2011 | Samsung WF337AA Front Load Washer
Load capacity
2/3 of the drum to the top loosly packed.... no more than that ... the clothes have to drop from the top and down to wash properly, and if overloaded you can rip the front boot off.....300 dollar repair....use he detergents and only use 1/5 of the cap as you have very little water in the washer.....Try to do atleast 2 hot loads a week to avoid mold and mildew smells and buildup....I have been fixing washers for 14 years please follow my advice
Jul 18, 2009 | Whirlpool WFW9500TC Front Load Stacked...
Front loader smells like stale cigarettes during cycle
Make sure that you are using high efficiency (he) detergent. Pour 2 cups of vinegar in the tub and fill the detergent tray with vinegar. Run it on the hottest, longest cycle. You can also use a Front load cleaner such as Afresh, made by Whirpool. I think that Tide makes one too. Vinegar is usually readily available. At the end of washing for the day, leave the door to the washer slightly open so that fresh air can get in and dry it out keeping moldy, milduey smell down. If it mildews, use a rag and bleach water to clean the boot seal. Hope this helps.
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
Oil leaking from washer
if it smell like wd 40..your transmission is defective,,need help replacing post question,,
Dec 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
Musty stale smell
HI thanks for your question. ALL front load washers have the same problem.MY solution every wash use 1 cup of vinegar in time will solve the problem. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | LG WM1814CW Front Load Washer
Foul Smell from my GE Adora Washer..!
Having the same problem as everyone else , I make a habit of cleaning the filter once a month. I would like to advise people that if your load is heavy (such as scatter rugs) they will not spin out completely even when the filter is cleaned. No more GE for me!!
Aug 21, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
