Question about Jenn-Air JCD2389G Side by Side Refrigerator
My Jenn-air *** has all but quit producing cold although the freezer is still working fine. So is the light on the *** side.......any ideas.....would it be the thermostat? My husband is out of state and I am trouble shooting this myself..........
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Posted on Jul 05, 2010
I have a Jenn-Air JCD2295KES side-by-side - freezer fine but the fridge too cold
The thermostat is not registering temperature correctly. If you have thermistors they should be replaced
Feb 27, 2014 | Jenn-Air JCD2295KES Stainless Steel
Jenn air side by side JCD2389GES ****** still won
If there are only a few rows producing cold from the freezer it may be a Freon leak. Remove the rear panel inside the back wall of your freezer and examine the frost pattern. When a refrigerator has enough Freon it will have the complete evaporator covered with frost. Here is a photo of what a frost pattern looks like with only a few rows.
Frost Pattern Only Two Rows
Click photo to enlarge
Unfortunately if this is what you see with evaporator exposed you will be better off shopping for a new replacement refrigerator because the cost to repair is just not worth the expense to have someone repair your refrigerator. If you have questions please ask, Thanks Sea Breeze
Sep 11, 2012 | Jenn-Air JCD2389G Side by Side...
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
Motor is running but it is not cold fride and freezer are 60deg
Sounds to me like the compressor has become faulty. it is not able to start. After a while the clixon starts to burn which explains that smell. Suggest replacement.
Sep 16, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigeration side not cold - freezer fine
Please remember the refrigeration side is a empty box the cooling is coming from the freezer side using a fan blowing through a hole cover by a slide and you can slide this cover wide open for colder in the refrigeration side or less as you wish. Hope this can help. God Bless.
Jul 14, 2009 | Jenn-Air JCD2389G Side by Side...
I have a jenn air side by side. the freezer is
This is usually a sign of a defrost problem. I will need you model number to help you better. Sea Breeze
Jun 26, 2009 | Jenn-Air Refrigerators
Freezer side works fine
you probably have a defrost issue. things to check are:
defrost heater not open circuit
there is often a thermal cutout in series with the heater and this may be open circuit.
defrost sensor may be wrong value.
fault in module
Jun 25, 2008 | Jenn-Air JCD2290HES Side by Side...
Jenn Air JCD2389GTW Refrigerator problem
The auto defrost timer was broken, so my refrigerator repairman replaced it. The part is about $60. The bigger expense was the labor getting to the timer, which is in the upper right hand corner of the refrigerator within the plastic casing that houses the temperature control levers. He then had to remove the panels of the freezer and defrost the coils with a blow heater. It took several hours.
Feb 28, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
148 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
