Question about Vehicle Parts & Accessories
My toyota previa m reg car battery died i took the battery off to charge now i have put the battery back on the immobiliser has kicked in an will not let me start the car is there a way to start the car again?
    Problem Solver:
  • 5 Answers
If by immobilizer, u mean that your key wont turn in the ignition, just keep turning to the right. Same thing happens w/my 92 after i replace the battery or turn the wheel 2much after turning off the van
Posted on Aug 03, 2010
I have a 1999 Toyota solara. The battery died. When I charged the battery now the alarm sounds and the car want start. How do I reset the immobiliser
Hello, try doing this:
with the key out of the ignition disconnect the negative battery cable
put the key in and turn to ON, leave door open
reconnect the battery
if the alarm stays off enter the car and leave door open try to start.
This works on most non factory installed toyota systems.
Dec 03, 2014 | 1999 Toyota Camry Solara
92 Previa, loud bang and van died any idea what happend? What could the bang be?
loud bang could of been your battery. have you replaced the battery? any problems since?
Apr 21, 2014 | 1992 Toyota Previa
1993 toyota previa was on hwy wouldn't go over 70mph then started losing power took first off ramp by then alot of white smoke was coming out the back end and died before it came to a stop
and oil level on engine is full?
was that smoke oil smoke or steam,?
no matter, id do a compression test on it,
if the engine (unstated type) is interference engine
id do a leak down test by hand, so as to limit further damage.
Feb 02, 2014 | 1993 Toyota Previa
I have a 1984 toyota not charging battery, i put on a new Alternator ,i took postive cable off battery it dies.
A Toyota will not run with the battery disconnected, it doesn't mean an alternator problem only a voltage and load test can determine that, it is unique to S\some Japanese cars and light trucks.
Jul 13, 2012 | Toyota Cars & Trucks
Toyota previa stalled (died suddenly) while being driven it feels like there's a hiccup in the engine no matter how hard i press the accelerator it won't accelerate!
Ika, has it started back? If not, it may be a timing belt/chain broke. If it cranks, it may be a fuel pump, filter, pinched gas lines, or bad fuel injectors. It may be a problem in the ignitions. Spark plugs,coils, wires, distributor, coil pack, dist.cap, If it is not cranking, check ignition fuse. Check battery, wires, and whole charging system. If it is just dying on you and it starts back, it may be a map sensor, idle sensor or throttle sensor possibly. Need a little more info please.
Mar 07, 2011 | 1993 Toyota Previa
1991 Toyota Previa won't start
low voltage to starter. Check battery for proper charge (must be 12.5+ volts), clean and tighten battery terminals. If below 12.5 volts, charging or battery replacement is needed. Hopefully this helpd
Sep 03, 2009 | Toyota Previa Cars & Trucks
91 Toyota Previa shaking and missing
you need to replace the fuel sock in the tank and the fuel filte and do a tuneup wires plugs and cap.
Jun 21, 2009 | 1991 Toyota Previa
Toyota Previa shakes over 60 mph
need a better description mrs ,like does the steering wheel shake ,does the car wobble at slow speeds .Better still as this vehicle is over 10 yrs old trade it in on plan new and get 2000euros back against a new car
Jun 21, 2009 | 1992 Toyota Previa
My previa keeps refusing to start
It might be a bad ignition switch located in the steering column. Try wiggling the key as you start it, is that helps, it is most likely a bad connection.
Jan 16, 2009 | 1995 Toyota Previa
Audi a4 1.8 avant 1997
my 97 a4 would start and then die, i had it diagnosed as the immobiliser in the dashboard costing about £600 !!! The battery went flat trying to start it so i took it off the car and charged it up, when i put it back on the car before i took it to get fixed i thought i would try it 1 more time and "hey presto" it started and ran and has not missed a beat since ! That was 2 years ago, it was like the computer had re-set itself with the battery removed for charging, i hope this may be of some help.
Sep 10, 2008 | 1997 Audi A4
Vehicle Parts & Accessories Logo
292 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
